Hey Manel, good to see you holding the fort as always :)
If you didn't know already, you can get Intel's Smackover fan here: http://click.intel.com/Fan_Kit_for_I...8SO-P1982.aspx, you would also need this part to mount it: http://click.intel.com/MCH_Heat_Sink...ket-P1674.aspx
I got one about a year ago and boy does it make a difference to my MCH heatsink temp. I was in the same boat as you. I looked everywhere for a quality 40mm fan but couldn't find one anywhere, so i settled on Intel's one. When pluged into the dedicated MCH fan jumper on the board, it runs at full speed and can't be controlled, so as a result it isn't the quietest fan in the world, nothing to loud, but it does have a low hum to it. Also, it does have a blue led light in it, i didn't like that at the start, but i'm used to it now and actually don't mind the soft blue glow eminating from my case. (At least it doesn't flash, i don't think i could've gotten used to that)
And my, doesn't that DX58SO2 look like one Bad A** piece of hardware !
