Can anyone confirm how these heatsinks respond to being upside down?
Lian Li V2000B Plus 2 on the way.
Can anyone explain to me why I fail the RAM test in OCCT 1.1.1b within 25mins yet I can prime blend for 15h straight? This has always been an issue with me and this build. It doesn't matter if I run my ram at 800 or 1100mhz, it will fail the RAM test in OCCT 1.1.1b within the first 30mins or so. Yesterday I prime blended my system for 15h straight without an issue before I stopped it myself. Seems odd to me. If I try any version of OCCT prior to 1.1.1b it fails in less than 10 mins. Strange how different version allow me to run shorter or longer when compared to other versions. I can however run the CPU&RAM test without issue. Is there something I should know? Anything I should be worrying about? Surely 15h of prime blend would call my system stable would it not?
It's a software error. I just hunted down a new beta version. 1.2.0.b07. This passed the full hour RAM test the first time around without making a single change to my system. OCCT is highly regarded yet it should be taken with a grain of salt as each version produces very different results. I am glad it was just a problem with the software and not my system however. So far the newest 1.2.0.b07 is the way to go for stability testing your system using OCCT.
Can you post a link for that beta, tnx.
Cheers man.:up:
It seems like this board has similiar bios settings as the X38 version.
If you guys dont mind, if anyone has a e6850 at 4GHz for 24/7 please post
your settings to help me out
I haven't got any proper 24/7 stable settings but I do have an E6850 that does 4GHz with 1.4625v 1.5vnb 1.35v vtt all GTL's @ 93. The GTL's make all the difference over 4GHz to stop it re-booting. I suggest you get Praz's cheat sheet from here: http://edgeofstability.com/index.html its a good start & then you can work from there.
CN :)
How is the vcore( vdroop) of this Board, with that V-core control function enabled, how much is the difference between Idle and load?
Well, I got a brand new DFI LanParty UT P35-T2R sitting here behind my desk that I bought for a friend. Friend is flaking on payment so it looks like I may have to eat it and use the thing:shrug: Think I'll like it??
I was really thinking about picking up the x38 version but then I don't feel like loosing $ on restocking and shipping fees!:down:
I love my IP35 pro, it's solid as a rock and uGuru is great but it looks like this DFI should do better. I'll give the guy a few more days and then may have to jump into this thread.:up: Thanks
anyone having issues with vista and X-Fi sound card with this motherboard?
Fresh install of 32bit Vista but Keeps on rebooting when BF2 starts loading.
I'm just having a problem with my Samsung S203N SATA DVD Burner, it just won't read anything...I'm wondering if I should try to have the JMicron controller take care of it...
Im currently using the IP35-e. What sorta performance improvements will I see with this board? Its either this board or the Lanparty P35 DK as my next board.
Any of u owners of this board gonna step over to the LP X38?
I don't think it's much of a gain in performance for anyone owning the P35 LP to step up to X38.
It's better to spend that money on something more useful.
which is the best bios again? was it the 9/13 or the 10/05? so sorry i forgot
