There were plenty of cards that had an overclock section, overall they had a pretty good gain from the overclocks. So the card/architecture has some good potential for revisions and such with a die shrink.
Y READY (bought 5870 6 month ago);)
GTX 480 has the best performance per watt in folding and DX11 Unigine. You see what you want.
The performance per watt in "legacy apps" is lower than 5870 for the same reason it is higher in newer apps. Fermi has all that excess hardware to make the new apps run faster. Pick your poison. Better old or better new. Nothing wrong with either depending on what you do.
HWG make very god review. Please use language tool. :)
http://www.hwgurus.com/testovi/grafike-karte/152.html
Orderet 2xGTX480 ;)
my personal opinion!!! as it stands now. this is not a good card. With a die shrink and a rework of the arch it can be a great card. I would not personibly buy it it in its current form. in yhe future possibly yes, okay peace out
Most people dont even take into consideration that 5970 was introduced to compete with high-end fermi. It is just remarkable that the 5870 has almost near similar performance,and being compared to fermi is a great testament to what Ati accomplished. Like it or not, Ati b!tch slapped fermi like a pimp and his ho.
http://www.tomshardware.com/reviews/...0,2585-15.html
No, no it doesn't... in fact the cards fall dead last compared to the 5970, 5870 and 5850 in perf/watt in Unigine
You don't compare a 480 and a 5970 because the 5970 costs $200 more. It's also just as available as Fermi.... good luck finding one off newegg. And dual cards are simply a pain, it takes more work to get that FPS because of the lack of multi-GPU support in new games.
