But it errored after the bench was finished. Have a look, Total computation time is showing. It's like getting a Send/Don't Send error at the end of a 1m run but still having your time showing. Isn't it?
@Knut
The CPU is a CCB3F 0711VPNW, and 4144MHz is my maximum validation. My RAM's absolutely maxxed out, this DFI won't post at any settings with the vdimm at over 2.2v, hence running 2T as well. I'm going to flash back to a pre-Phenom BIOS sometime and try again.
It's this RAM, 600MHz C3 on (cooling and voltage withheld to save me from getting a beating from certain people :p: ) so once it's running properly I should be able to run again at C3 1T. And before you ask if the RAM's dead, it's busy memtesting at 533MHz C4 1.8v (I always do it after a heavy bench session) so it's fine :up:
