Thumbnail works for me, very nice Pete
I didn't have show images enabled, so it just showed a link. When I clicked on the link it showed a very small picture. Now I see.:)
How come you have so many processors?Quote:
Originally Posted by Pete@X
Any chance of an A64 Tweaker ss please, and which Samsung UCCC 2GB kit are you using :)Quote:
thanks
Very nice cpu there :woot:Quote:
http://www.cpuid.com/download/cpu-z-132.zipQuote:
Originally Posted by RMSwins
I ordered mine on 12/31 from newegg, received a 0530 170.Quote:
Mine is a 434L, ive stopped my testing now, am happy with 280x10 1:1. Will try to overclock some more once ive changed mthbrd (common ati chipset i need you :))Quote:
Originally Posted by nealh
Oh vCore is 1.475 set in bios
Here´s my 170 0550VPMW:
http://img71.imageshack.us/img71/318...142v9vw.th.jpg
This chip is really hot, this is the max i can do for now on air (BT). Next week i´ll change to wc & if i see it´s worth i´ll take out the ihs.
That is very nice Vcore for 2.9GHz :toast:Quote:
Originally Posted by Cordovader
Okay starting playing with my new system. Got it up to 2,8 gig. 10 hour prime 95 stable at 1,55 V even though the PSU is showing 1,53 often...
Think my Gskill which I run 1:1 at 1T may be on it´s limit though... But trying higher voltage on the CPU to see if that helps :).
But on air I should have gotten a decent chip it feels like :)
Are you kinding me..your cpu temps are great on air....damn the 170 0550 upmw is clearly not as good as these 170 0550 vpmw...so many more excellent results with low vcoresQuote:
congrat :toast:
Thanks ;)Quote:
During the pi´s the temps went up to 49ºc, and from what i´ve seen from this chip, passing the 50º barrier almost equal to instant error :(
That´s why i want to try it with water, i think i can reach 3ghz stable then :D
Nealth, referring to this post i´ve changed from a 0546XPMW (max stable 2,8ghz 1,52v) to this 0550VPMW. You can see the difference ;)
I see a lot of people here claiming Super Pi as some sort of stability. Lets see some dual instances of prime and see what happens. i can dual super Pi my 170 at 2.9ghz+, but only prime at 2.82Ghz.
big difference between superpi and prime.
good point!
yes prime 95. And minimum 12 hours. I have tried running 280 and have had prime95 blend torture test running 10 hours once before crashing 8 hours another time...
But it just don´t seem possible without changing some RAM settings or anything in a way Idon´t know lol.
That's a great chip. 2.9GHz only 1.424v on air. Amazing. Congras.
PS:// Is it dual prime stable? :)
This is XS and if a person feels dual spi 32m and games are all they need to make their rig do what the want it to, that's thier choice.Quote:
Originally Posted by cdelong
Live and let live.
most people would agree Prime95/SP2004 is the "standard" stabilty test for CPU/memory sub-systems. That's all I'm pointing out. It helps to compare apples to apples for stability comparisons.... ie.- Super-Pi stable @ 2.9Ghz does not necessarily = Prime 95 stable @ 2.9Ghz.Quote:
Originally Posted by dogsx2
This IS the forum thread people come to when they want to see what steppings are doing real well on OC's. :toast:
As dogsx2 says, for me spi stable & gaming is enough stability for the use i give to my computer.
That doesn´t mean that i can show you guys a shot of prime/sp2004 to show stability but i´m going to left it until i get my new wc (& found some time to pass those stability benches).
Most people here know that spi 1m is not as stable as 32m and 32m is not as stable as prime.Quote:
DFI LANPARTY UT nF4 SLI-DR Expert (12-7-05)
AMD OPTERON 175
Patriot Dual Channel XBL 2x512MB PDC1G3200+XBLK (tccd)
EVGA 7800GTX 256MB, PCI-E
Western Digital Raptors 2 * 75gigs
Western Digital Raptors WD740GD 74GB 10,000 RPM
LITE-ON LTR-24102B
PLEXTOR DVDR PX-708A
SONY DVD-ROM DDU1621
PC Power & Cooling 510 SLI-PFC ATX12V 510W Power Supply 90 - 264V UL/ ULC/ TUV/ CE-Retail
Genie BIOS Settings:
FSB Bus Frequency - 275
LDT/FSB Frequency Ratio - 3
CPU/FSB Frequency Ratio - 10
PCI eXpress Frequency - 100Mhz
CPU VID StartUp Value - STARTUP
CPU VID Control - 1.550v
CPU VID Special Control - Above VID * 102.4%
LDT Voltage Control - 1.40v
Chip Set Voltage Control - 1.68v
DRAM Voltage Control - 2.84
DRAM Configuration Settings:
DRAM Frequency Set - 166=RAM/FSB:5/6
Command Per Clock (CPC) - Enable
CAS Latency Control (Tcl) - 2.0
RAS# to CAS# delay (Trcd) - 03 Bus Clocks
Min RAS# active time (Tras) - 06 Bus Clocks
Row precharge time (Trp) - 03 Bus Clocks
Row Cycle time (Trc) - 10 Bus Clocks
Row refresh cyc time (Trfc) - 13 Bus Clocks
Row to Row delay (Trrd) - 02 Bus Clocks
Write recovery time (Twr) - 02 Bus Clocks
Write to Read delay (Twtr) - 02 Bus Clocks
Read to Write delay (Trwt) - 02 Bus Clocks
Refresh Period (Tref) - 3120 Cycles
Write CAS Latency (Twcl) - Auto
DRAM Bank Interleave - Enabled
DQS Skew Control - Auto
DQS Skew Value - 0
DRAM Drive Strength - Level 11
DRAM Data Drive Strength - Level 1(Reduce 50%)
Max Async Latency - Auto
DRAM Response Time - Fast
Read Preamble Time - Auto
IdleCycle Limit - 256 Cycles
Dynamic Counter - Disable
R/W Queue Bypass - 16 x
Bypass Max - 07 x
32 Byte Granularity - Disable(4 Bursts)
Prime95 + 3dMark2001SE + CPU-Z 1.32 + Everest 2.50 Ultimate Edition 2006:
http://joek71ny.tripod.com/images/finaltest.jpg
http://joek71ny.tripod.com/images/finaltest_1.jpg
http://joek71ny.tripod.com/images/finaltest_2.jpg
http://joek71ny.tripod.com/images/cpu-z.jpg
http://joek71ny.tripod.com/images/mem_settings.jpg
http://joek71ny.tripod.com/images/memslot.jpg
http://joek71ny.tripod.com/images/memslot1.jpg
http://joek71ny.tripod.com/images/setting1.jpg
http://joek71ny.tripod.com/images/prime95_14hours.jpg
3dMark2003:
http://joek71ny.tripod.com/images/3dmark.jpg
EVEREST 2006:
http://joek71ny.tripod.com/images/everest_latency.jpg
http://joek71ny.tripod.com/images/everest_read.jpg
http://joek71ny.tripod.com/images/everest_write.jpg
short description:
275*10 @ 2750Mhz, 5/6, 1.550v + 102%
2.0-3-6-3 @ 2.84v vdimm
well i found a seller that's got 4 CCB1E 0550VPMWs at a decent price, pm me and i'll link you
You got PMQuote:
165 or 170 :confused:Quote:
