Originally Posted by Nano2k
hahahah my cabge hit 3g easily with air :)
He said in geenral... yours must have been a nice chip. :)
Anyway I have a 146 CABYE @ 3ghz now stable... loving it to bits. :slobber:
Super PI time seems a tad high though at 29 secs lol... but PI loves 1:1 doesn't it?
3 ghz 1,6v 44*c full load
0536 cabye 144 opty
waterchill h2o
Thats why I said "in general" :toast:Quote:
Originally Posted by KeZzZu
My results :) Will try higher later on :)
http://img120.imageshack.us/img120/1...oldude25ys.jpg
[Ignore the PSU Rails, they're false readings]
so CAB2E also not bad at all
nope :) going to see if i can hit 2.9, maybe 3 :D
I am happy as 2.8 was my goal, so if it doesnt do any more i wont be that bothered but ovbiously it'd be great if i can squeeze another 100/200mhz out of it :)
Thx,
cool_dude
Im getting mi opty 146 or 144 in a couple of weeks... to chile only arrived the 150 thats extremly expensive...
If im lucky i wil get a good stepping hoping for a CABNE 0530 or better...
How do you think and opty will run under a Zalman 7000B AlCu?
I'll let you know on Sunday :)Quote:
Originally Posted by DeToNaToR.cl
Suman
Originally Posted by Richdog
Low Latency and 1:1 helps Super PI alot. I pulled out a 29sec SPI with my CABYE @ 10x290 3-4-4-8.
My TT BT is on the way, hopefully that will get me to the magic 3ghz. If not as soon as the prommie gets fixed i know it will :D
What type of load temps are you getting with your Hyper 6?
I have the Coolermaster KHC-L91-U1 but won't get my opty until next week or the week after.
thanks
Doing some burn in with Opteron 146 using high vcore as <1.6v vcore temps only max 45-46C on Cosair Hydrocool 200 water, not enough to burn in cpu apparently...
http://fileshosts.com/DFI/NF4_SLI_D/...ad_3040mhz.jpg
Graphs using MBMLog plugin http://i4memory.com/showthread.php?t=1635 :D
Yea, any cpu that can do that is pretty good. :D Ambient 22c with Koolance2 with heatspreader on. ;)Quote:
Originally Posted by Zeus
http://img240.imageshack.us/img240/8352/30312qs.th.jpg
http://img240.imageshack.us/img240/6...occt8ap.th.jpg
Does 30c idle @22 ambient at 1.4v sound about right with a Koolance2? Is there a trick to seating it right? Any advice would be helpful.
what's with the OCCT text font being different ???Quote:
Originally Posted by dogsx2
One says I was almost done, the other says I was done. Didn't cost anymore so I thought I'd show both. :DQuote:
Originally Posted by eva2000
I noticed tht also, is the system missing fonts?Quote:
no i mean font type
http://www.fileshosts.com/DFI/NF4_SL...inished_tn.jpg
Where do you change the font type ?
Originally Posted by ixtapalapaquetl
tighter timings brought stability?????
http://users.skynet.be/pt1t/146/146_...55v_occt_b.jpgQuote:
that s right font :D
Do you check the new CPU-Z beta version about Vcore? it seems to be that now shows the real voltage. At least the voltage that you set in Bios.
Originally Posted by corvus_corax
Do you have link ?
My bad.Quote:
Originally Posted by Pt1t
Here:
http://forum.x86-secret.com/viewtopic.php?t=4221
thanksQuote:
