Wow!
Wow!
Nice Skirms.
Oh yeah i forgot to ask earlier people using a P4C800-E is it worthwhile using better cooling on the NB? Such as water or maybe a small pelt
nah...Quote:
Originally Posted by marvt74
Originally Posted by Neova
:woot: :woot:
my latest run wiith a m770 at -5C with a very poor single stage that needs sorting.
booted at 200fsb with turbo and pat ram at 2-2-2-5
http://www.ljsnet.co.uk/benchin/m77023sec.jpg
ram at 222 5222 ?
which mb ?
p4p800 se with vdimm mod
geil one bh5 @3.3v
it will do 240 2-2-2-5 at 3.3v but i need my booster mod working before i can go any higher.
Originally Posted by skirms_fr
If you boot at 200FSB on the p4pse you don't get AGP/PCI locks - try booting at 199MHz - you get your locks and you still get full PAT.Quote:
Originally Posted by leejsmith
anyone any ideas to help me my dothan hits a wall at 2.67ghz at 1.4750 v
191 x 14
it doesnt matter what multi i use it hits a wall at 191 fsb anyone any ideas
i,m on a asus p4p800 se with stock air cooler and stock adaptor
http://img.photobucket.com/albums/v1...wade/test1.jpg
its like i have hit a wall
i dont get locks with a ati 9250 but i do get them with a 6800gt.
but will try and see what it does.
I thought pat and turbo at 200fsb was differant settings than when at any other fsb plus you dont get the correct ram speeds so i would only have 333 instead of 400 , 500, 533 at fsb < 200.
Originally Posted by wwwww
OhQuote:
PAT and turbo at 200 is the same at 200 or lower. 201 and above is slower.
at 199FSB, 266 = 1:1 and 333 = 4:5
but yeah if you get locks with the 6800gt it should be fine.
would setting ram latency to 11 in 865 ram tweaker be the same as pat and turbo at 200 ?
this would help with my 9250 quest for #1 spot in 3d2k1
Not exactly. DRAM latency parameter 11 set in i865 tweaker is fast, but its no substitute for a straight 200MHz 1:1 boot. The board sets some parameters that aren't within our control unfortunately at 200 1:1.
nice results lee
i hope to see more records come back to UK, well.. not really back i guess :rolleyes:
thanks i did have a better time but didnt record it as i thought i would do better.
yeh im sure you willQuote:
look forward to it
how are you getting on with the 760 ?
http://img277.imageshack.us/img277/9626/bench6yz.jpg
My little contribution
slow fsb because of my motherboard (P4P800VM vdimm 2.65v max)
Cpu is stable prime for 12H at 2765Mhz v core 1.55V
http://img514.imageshack.us/img514/4039/untitled2bp.png]Quote:
http://img514.imageshack.us/img514/1738/245788ls.png
I took my IHS off now coz it wasnt stuck and now w/o ihs i can't get good temps with my 7000alcu :S
i will reattach the IHS tomoz and see what I can do
oh and I also took back my 3dmark01 wr with 6800LE @ 2927mhz
I actually got 33723 but it wont publish coz i CGed after opening 3dmark :(
Pretty good :D
What is vcore bios setting ?
1.575v (1.61v real)Quote:
Originally Posted by 200%absolut
and thanx :)
my Max stable
forget to make a screen after 10h prime :s
http://img455.imageshack.us/img455/6...spi32m29aj.jpg
Nice larwy what room temp is it for this speed and why is your ram speed so low.
twas about, well i dunno really, my little thermometre is weird, if i select OUT it says about 7'C, if I select IN it says like 13'C so... lolQuote:
full PAT.. theres no gaing me running a higher fsb and partial PAT because I have to loosen to 2.5-2-2-5 as I only have 1gb ballistix atm
Hmm just whacked my 730 in for the first time and i'm getting temps around 50C
Still at normal vcore and stock heatsink
what kind of temps are other getting or is the p4c800 likely just reading high?
