please share:D
its on evy site
Dual EPS mod done, I used two of the blue PCIE cables and plugs, taking two 12v and GND from each. Initial tests show absolutely no difference at all. lol I'll try some 4.5GHz LinX later to see if it's stabilised things there at all.
EDIT: It might just be me (and Linx testing later will confirm) but I think the CPU is running cooler now...
Well radaja.... did you get the board?
Did you do the dual EPS mod for it?
not yet.
i cant seem to get the x21 to work?
in bios it only lets me set 12-20.
im running bios 6/30/10 rev13 but i tried
running 21x215 and it just wont do it?
radaja, if I enable turbo it still shows 21x multi on this 930 in bios but in windows it shows the 22x multi.
Managed to get 2300mhz mem but looks like it drops a channel unless I raise the timings.
http://img43.imageshack.us/img43/3624/23001.png
Uploaded with ImageShack.us
ok,i was looking at your bios SS's and thought i should be able to do 21 too:D
but i dont own a 930 do i?no i dont:ROTF: my first classy fart
you know i never checked,i just kept rebooting into the bios to see if any of my
changes i tried had worked and then when i finally booted into windows it failed
so loaded defaults and then posted here on how to fix it:D
man these voltages are whacky,it loads my vtt at stock as 1.24v so +100 gives
1.36v but load it jumps to 1.39v.
you test with dmm? e leet reads very high but with a dmm vtt was much lower.
Just started linx, e-leet reads vtt at 1.37v and dmm reads 1.28v. have it set to +75mv in bios
i havent tried a DMM yet but i will soon.what kind of temps are you getting on vreg and NB and MB sensors?
i got the AC blowing in hard and still at 27c vreg/39c Nb/17c MB? i cant figure out how to get NB and vreg
temps down like the MB sensor.i have three 40mm fans blowing directly down ove socket and another on NB
nice:up: the P35-UT-T2R stomps my EP45-UD3P.but soon i will rectify this:D
took 1.71v dram and 1.60vtt. stopped after that, dont want to kill anything.
vreg is 29c, this software doesnt show nb on this c3 yet, only place to check is in bios, which doesnt do a lot of good. with your cooling im sure everything is fine.
aida64 and everest read board as unknown still.
http://img534.imageshack.us/img534/2165/tempss.png
well im off to bed,but i did manage to get the hang
of this new MB and will play all day tomorrow with it.
http://i54.tinypic.com/23ra0sz.jpg
wow...great CPU!!!
use mch strap 1333 and u will get better timings
the new bios
hmm seems a lot of ppl dont know how to use it
with the tWL and tRL ( it was incomplete without the tWL)
and the tREF
u can use any other manufactorer ram timings
example like r3e bclk 200 C8 2:10 timings
http://i287.photobucket.com/albums/l...1/af11e3ee.png
r3e timings are much more mem timings tighter but
less strained for ure Uncore especially on C7 and C6 on 2:10
^^ Thanks, strap makes a big difference in sub timings and in aida64 bench, I was using 1600 to try and keep it stable. Trying 1066 strap, required 1.67vDimm.
http://img577.imageshack.us/img577/8905/1066strap.png
just raising uncore seems to give me the best boost even with 1600 strap.
http://img217.imageshack.us/img217/5992/21uncore.png
Wow Nub, 4.5GHz Uncore on a 930 on water....do I even want to know how much Vtt you are feeding that poor thing?
Iam testing the new bios 77 with my 980x on SS and works great
http://img146.imageshack.us/img146/2201/screen030q.jpg
http://img713.imageshack.us/img713/3637/screen029r.jpg
Nice one, 5-6-5-X at 798 MHz. Good to see CL5 working, could never even get that to boot on my R2E.
