ROFL @ Asus reply.
So what are people getting by doing this flash? I haven't seen and before and afters.
Thanks, great mod. Will have to play around more.
I can confirm raid still works after mod.
Ok ok...I caved...
Now the proud owner of a Maximus Rampage!!! And that's my name for it, hands off! :D
Man... I think this weekend I'll follow suit.
I just wish I had a decent CPU to run before/after benchmarks on.
I'll do it anyway... unless the rest of my parts come in and I'm building. Either way, I'll be sure to do some benchies before and after the flashing.
i got this pm from a guy who doesnt accept pm's so if you are reading this dude, here you go
Originally Posted by miklink
my current settings, as im still using this cpu till this weekend, are... (bear with me im doing this all from memory but its accurate)
Extreme Tweaker
Ai Overclock Tuner : Manual
OC From CPU Level Up : AUTO
CPU Ratio Control : Manual
- Ratio CMOS Setting : 9
FSB Frequency : 437
FSB Strap to North Bridge : 400
PCI-E Frequency: 120
DRAM Frequency: DDR2-1165
DRAM Command Rate : AUTO
DRAM Timing Control: AUTO
DRAM Static Read Control: ENABLED
Ai Clock Twister : STRONG
Transaction Booster : ENABLED 0
CPU Voltage : 1.481 (the one right above 1.475 flat)
CPU PLL Voltage : 1.61
North Bridge Voltage : 1.51
DRAM Voltage : 2.26 (my mem rated to 2.35)
FSB Termination Voltage : 1.54
South Bridge Voltage : 1.10
Loadline Calibration : ENABLED
CPU GTL Reference : .63
North Bridge GTL Reference : .67
DDR2 Controller REF Voltage : DDR2_REF
SB 1.5V Voltage : 1.5
NB LED Selection : NB Volt
SB LED Selection : SB Volt
CPU LED Selection : CPU VOlt
Voltiminder LED : DISABLED
Advanced CPU Configuration
C1E Suppport : Disabled
CPU TM Function : ENABLED
Vanderpool Technology : Disabled
Execute Disable Bit : Disabled
Max CPUID Value Limit : Disabled
USB Configuration
USB Functions: Enabled
Legacy USB Support : ENABLED
hope this helps, the maximus likes to over volt so watch your cpu ppl, ram, north bridge, and fsb term voltages.
-Effect
http://www.tyan.com/tech/matrix_flashUtility.aspx
check this out :up:
afuwin 4.24 has a /x function that ignores rom id
afudos v.4.04
Interesting find. Well done.
I've found my first bug in this Rampage bios. Occasionally the multiplier won't change regardless of what you set it to, eg:
I was running 9x and the switch to 8x, but even though the bios settings saved and everything else changed the multi was @ 9x when I rebooted and re-entered the bios.
Now it's either getting stuck @ default multi or sticking @ the last multi used before changing, not sure yet.
I wondered why my boot kept failing and then it got a bit further and I saw I was booting @ 4.2GHz with 1.45v! :D
well nuts.
but, if said afudos emerges *i can search like a mofo* that is the engineering version.
1.) how would i identify it as such?
2.) could i do a direct flash instead of the hacked front-end loader as was this thread was based upon?
id rather do a direct flash if possible than do it from a usb stick as i dont have one handy:( will ez flash recognize cd?
I think so, from what was said up there ^^^? Easiest way to try would be directly flashing the Rampage bios, if it works with those parameters then it'll work to flash back too... If it doesn't work then you'll have to ask The Stilt for a recovery method?
well... i did it.
http://i48.photobucket.com/albums/f2...ageformula.jpg
greg, why does my write and copy suck? what do i manipulate to up those?
and now that i know what is needed I WILL FIND THE ENGINEERING AFUDOS
if i could, i would buy stilts a drink!
