Originally Posted by gtj
1.5v isn't a problem provided you can keep your temps in line. I run 1.55v.
QUOTE]
ugh. crash-fest. i cant get 3.3ghz. tried 3.2ghz @ 1.475v. windows boots fine. orthos crashed after 15mins.
brought everything back to 3.0ghz @ 1.45v. now orthos wont run for more than 10secs. same exact settings i have been using all week.
ugh.
Type: Blend - stress CPU and RAM Min: 8 Max: 4096 InPlace: No Mem: 1789 Time: 15
CPU: 3006MHz FSB: 266MHz [261MHz x 11.5 est.]
3/7/2007 8:51 PM
Launching 2 threads...
1:Using CPU #0
2:Using CPU #1
1:Beginning a continuous self-test to check your computer.
1:Press Stop to end this test.
2:Beginning a continuous self-test to check your computer.
2:Press Stop to end this test.
1:Test 1, 4000 Lucas-Lehmer iterations of M19922945 using 1024K FFT length.
2:Test 1, 4000 Lucas-Lehmer iterations of M19922945 using 1024K FFT length.
2:FATAL ERROR: Rounding was 0.5, expected less than 0.4
2:Hardware failure detected, consult stress.txt file.
2:Torture Test ran 0 minutes 9 seconds - 1 errors, 0 warnings.
2:Execution halted.
1:Torture Test ran 0 minutes 9 seconds - 0 errors, 0 warnings.
1:Execution halted.
then windows was crashing, w/o doing anything (again at same settings as before = 3.0)
im back to stock... try orthos now.
update: at stock.. orthos wont run for more than 5mins. same error
Test 3, 4000 Lucas-Lehmer iterations of M19374367 using 1024K FFT length.
i set my memory according to OCZ suggestions
4,4,4,15 @2.08v
thoughts?? im kicking myself for messing this up now.
update: now im getting all sorts of odd errors in windows... flickers.....
this isnt looking good.
