http://valid.x86-secret.com/show_oc?id=58965
Max clock, AIR cooler, 1.6V, no mods, old BH-5.
Stable clock:
http://valid.x86-secret.com/show_oc?id=58963
http://images.people.overclockers.ru/49774.jpg
Stable clock:
on P4GPL-X it overvolts if you set voltage to more/equal to 1.4V in BIOS.Quote:
yes, imo thats one of the biggest issues of those asus s478 pci-e boards.Quote:
Originally Posted by bcn
i just couldnt get stable voltage if i set vcore>1.6V -.-"
Should I pick up a Pentium M 740 with the stepping..
7418A068 SL7EN
RH80536 1800/2M
I'm hoping to stick this in my laptop and pin mod it without having to increase my voltages. Think I have a good chance?
The fsb pinmod only works with the 7x5 processors. According to that serial number, the processor is a 745. So the pinmod will work, but chances are that you're going to have to increase voltage (which you can also do via pin jumpers btw) to get it stable at 533MHz fsb. Your basically talking about running a B1 at 2.4GHz with 1.308 volts. Chances are it's not going to happen.Quote:
Originally Posted by JDizzle
BTW this is the wrong thread. PM me if you need some more info.
my dothan don't need volts, check this shizzle!
http://icekoldkustoms.com/Tommy/Uplo...s/4/2.7ghz.JPG
yeh, some don't..
my celeron M didn't.. but the ones that react to volts are gonna come out best tbh..
How many of you guys use over 1.6v?
and with what cooling? :D
i wouldnt use more than 1.6v for 24/7...at least not with air or wathercooling.
lost another p4c800-dlx.. in normal (def vcore etc) conditions..
comp hanged during bootup, refused to power up after that,
removed cpu, adapter, cards and ram and powered it up.
BANG and this big black cap jumped out.. almost hit me in the face..
http://alpha.frontier86.ee/~markku/dothan/cap1.jpg
http://alpha.frontier86.ee/~markku/dothan/cap2.jpg
nasty.. :S... looks repairable tho :)
http://www.asus.com/products4.aspx?l...71&modelmenu=1
Does that bad-boy have CT-479 support ? Looks like an P4GD1 killer :)
Seems to use Ati Northbridge, so I'd say no...Quote:
Originally Posted by DaWaN
We'll see.
You should do better then that...Quote:
Originally Posted by skirms_fr
I get this with mem @ 197 :D and a little higher oc...
http://img340.imageshack.us/img340/4373/2778ic.jpg
got my 760 under my big typhoon, with a VERY poorly lapped IHS (atleats its down to the copper), with the coldest air i've ever used to bench..
and set myself brand new records, smashed my old PB's :D
http://valid.x86-secret.com/show_oc?id=60132
http://img514.imageshack.us/img514/4039/untitled2bp.png
http://img514.imageshack.us/img514/1738/245788ls.png
Now I'm confused... I got a M 740 and it hits a wall at 2370MHz no matter what voltage or cooling. I'm running it atm in a P4C800E-Dlx with vdroop, vmem, vcore and vagd mods. The max OC does not change if I give it 1.25v or 1.7v the wall is at 2370MHz, this is kinda strange and uncommon, I also got a partly-modded CT-479 adapter and no use... Does someone have an idea where the problem is...?
Ram/chipset limitation? Try using a divider and a higher multi.Quote:
Originally Posted by gooFly
http://home.comcast.net/~gautamb/1m.JPG
Anyone want to get me to 22 secs?
:cool: what are you using for cooling now?Quote:
Originally Posted by Gautam
http://home.comcast.net/~gautamb/setup.JPGQuote:
Originally Posted by lowfat
Seems like my signature crap Dothan luck doesn't even end with 780's...
are you using the 11 latency?
if not, that should get you to 22 secs
if you are, get a higher FSB..
I have tested with different multipliers and I know that my board can do 270MHz (did it with my P4) and my new memory can do 255MHz at 2-2-2-5 so those two are unlikely holding me back. It's like a brick wall, no matter what multiplier, voltage or cooling (tried with the adapters heatsink) I throw at it is wount budge.Quote:
Originally Posted by wwwww
Looks like a real crappy CPU :/
Try 9x and see how far you go with the rest of your settings the same and 1:1.Quote:
http://112233445566.free.fr/PM740/22.969.jpg
740 under cascade r290/r170
