thx bro... saved. :D
I'm monitoring my monthly bandwidth, it's been downloaded 5 times so far :D Come on guys, everyone download it, we can resurrect this :D
I saw thanks Knut, but for some bizarre reason I can reply to PMs from my phone. I'll reply today :)
Opteron 146 CABYE 0540 APMW on way to me....looks like pretty fine i hope this will be a burner.
best of it was 0530 apmw also as the fx-57 stepping. but that cabye will be much fun under coldness.
FPBW ??? Lol....3rd place with that i cant believe it...
I have a 3700 sitting around, its batch no. is 0608EPMW. Will it overclock good? or not?
Thx
There's nothing in that thread that will help you enable unlocking A64 processors ;)
@ massman: There WAS, the thread was deleted while I was saving it though, I'm missing a few pages ;)
Because SD is faster :p:
hehe, nice gianni :D
gianni you freak ? Are you on holidays ?
@ Knut
Stepping of that FX ?
Yesterday I tested my Opteron 146 CABYE 0540 APMW....no cold bug by the way but there were too bad temps for overclocking....only -18c with default vcore and with 1.6 volts there were around 0c...need some better unit for cooling....i think in the next weeks there will be one great unit in the mail :lol: :lol:
New cpu-z version is out so i did the false validations :D have to make it again :( ...very hot chip, could go to 3.4 ghz with bad cooling....i think there is potenzial with more coldness...
Yesterday I tested my first !!! FX-60...its an CCB2E 0536 WPMW....3.6 ghz was possible with single stage and 1.6 volts but the temps weren´t good. So I hope if i get the cascade there will be 3.7 ghz and higher...cold bug is -24c and 230 mhz....
Found one X2 4600+ LDBFE 0607 SPAW with no cold bug until 400 mhz htt :banana: Could boot with that chip with 400x8 under single stage...
And the result is at the moment 3655 mhz with -24°c and 1.616 volts --> with more coldness the record could fall because i cant do more voltage on that chip and it easly defends on temperature. every celsius will helps on this way.
By the way, check my sig for my new 6000+ world record :D
hehe, nice work bro :toast:
Wow :eek: Nice cpu you got there Oj101 :up:
Maybe you should bench some 1M with that ? ;)
