impressive lowfat, what XP tweaks are you using?
ram drive, and that is about it i believe.Quote:
Originally Posted by Johnny Bravo
i know you from somewhere, lowfat :lol:
I can't believe I was so much FSB limited, No go above 240 or so. I hope Hipro's adapter mod will improve it. If not I will throw it to trash can :D
DMM measured
Chipset 1.8V
RAM: 3.6V (it was 270 benchable on NF4)
PCI-E freq. 110-130
Booted at 167+ for locks to work.
11229 3d2k5
http://service.futuremark.com/compare?3dm05=1567434
http://xs59.xs.to/pics/05505/24.8.jpg
Seems like you need a chipset vmod. I managed to do 262mhz on my mems 1:1 Superpi 1M without mods. Dunno how high the fsb will go.
1.8v is plenty, i doubt you'll get much gains from >1.8v unless you dice your NB :p:
I have a chipset mod already, tried 1.9V but that does not help.
And BTW, my OCZ EL gold sticks (utt bh5) do not work on this board at all. No post. So, I suspect the board is not good.
I had a play with a m780 tonight my toes are still cold after spending 5 hours out in the cold (-1C outside the shed 7C inside) everything air cooled.
i have a cpuz dump but it wont upload cause my version is old :(
1,Intel Pentium M 733, (dont know why this says 733 and cpu z shows 753 later)
Dothan, Intel(R) Pentium(R) M processor 2.26GHz,
6D8,00,22,0,C0,0.090,MMX SSE SSE2
3071.26 ghz , 11.0 x 279.21,
6.0,17.0,32,32,2048,,mPGA-479M,4,10D,
Intel i865P/PE/G/i848P rev A2, Intel 82801EB (ICH5) rev 2,
1024,DDR-SDRAM, 279.2,1:1,2.5,3,3,5,,,,2,Gskill,512,PC4800,Gskill, 512,PC4800,,,,,,,,,,,,,,,1100,
ASUSTeK Computer Inc.,P4P800SE,1.28.1,52C2E5E4837CC8E8C79CD67FD1691 623050580
my biggest problem is my ram this run was my best 1m super pi stable 24.20s
a 2nd run of this would cause memory errors. i need some bh-5 ram that will ruh at 260 2-2-2-5 this would greatly improve my scores.
i increased the multi to 12 and ran at 3033 for 3dmark but this ment my ram was not running as fast as it could and i dont think i can drop the ram timmings any lower .
this was at 440 gpu and 1200 memory 6800gt 256mb default vcore.
i could not get a 128mb 128bit 9250 card local only a 64bit one and the ram was verry poor but would run 310 on the core.
as i have now sold my current dothans and only have the 780 and 770 on loan i didnt fire up the single stage but do have a 770 es on the way soon and this ones a keeper.
http://www.ljsnet.co.uk/benchin/m780-3033-440-1200.jpg
and this was the max 1m stable before my ram died.
http://www.ljsnet.co.uk/benchin/m7803099 pi.jpg
again at 7C room temp in air
how much voltage did you put in it and for how long?
bios set to 1.6v i also measured the volts on my vdroop mod @ 1.6v
but anything i use to read the vcore in windows shows anything between 1.55 and 1.568.
never changed from 1.6v and was benching for well over 5 hrs.
Originally Posted by bcn
Dothan 780 @ 13x246=3203mhz / 1.66v / air
Asus P4GD1
4 x 256mb Corsair BH5 @ 246mhz / 2-2-2-5-2 / 3.3v
SuperPi 1M:
http://img527.imageshack.us/img527/5...x2468qk.th.jpg
24.094 sec
pretty good for air and I915 imho:D
GREAT :banana:Quote:
Originally Posted by Winterwind
What is 16M time ??
i doubt that i can finish 16M:DQuote:
I know that :) - but with lower clocks ...
dothan do 1M superb ... but 16M is quite poor (P4GPL-X i915PL in my hands)
I'm interested what is in yours ...
for example my A64 @2,9GHz (mem @ 240 2-2-2-5-1T) did 1m about 29s and 16M 12min 00(+/- few sek)
My Dothan can do 1M 29,8 but 16M 13m40s :mad: (2,5Ghz ram 208 2-2-2-5)
ok... new setup:
P-M 740, P4P800-SE bios 1010, Twinmos Twister PC3500 (my booster doesn't work properly unfortunatelly :( and that's why I have this small PSB :mad: )
so far... this is what I can get with boxed (CT479) cooler and 1.5V in bios (some Prime later)
and 27.92s in SPi with 210MHz FSB (x13 multi)
excellent chip :banana:
o.k here is mine
http://img.photobucket.com/albums/v1...wade/test1.jpg
cannot get above 191 fsb at all stock adaptor and mobo (asus p4p800se)
91% overclock
Originally Posted by -Acid-
Increase your VAGP voltage (1.8 volts) and lower your cpu multi in the bios (try 10x). Reboot, go back into your bios and start raising your FSB. Make sure your ram can handle the ram ratio and adjust as nessassary.
Nah his CPU won't likely go more, it's a B1, 191 is already good.Quote:
Originally Posted by Neova
on air with fanbox ct479
1.4 bios (1.5v real)
vdimm mod ok => 3.85 :banana:
http://112233445566.free.fr/PM740/27.5.jpg
hmm there's no way that you set 1.4v in bios and it's reading 1.536v in cpu-z.. :rolleyes:Quote:
Originally Posted by skirms_fr
1.536v is about the standard voltage most people seem to get with a non-droop modded board with 1.6v set in bios..
:bs:
1.4v bios = 1.502 multimeter on mobo
last screen of my dothan :
klick me
i should get my cedar mill within the next 1-2 weeks.
raiden
2.4GHz @ 1.192V??? wowoweeee, what's it's max?Quote:
Originally Posted by Raiden Zero
hm, 24/7 was 2,9Ghz@1.54V =)Quote:
Originally Posted by wwwww
2,4Ghz->1.2V
2,6Ghz->1.32V
2.7Ghz->1.43V
2,8ghz->1.50V
2.9Ghz->1.54V
:D
Maximum pirme-stable clock was 2,95g@1.63V...
But superpi clocks were not as good as i expected.
only up to 3g@1.68V for 1m -.-"
