The pumps on the TT w/c,ing kits are bad about quiting or use to be.
If you go with a kit go with Swift-Tech.
Sheeehhh...too dark....
http://img.photobucket.com/albums/v4...5/P1030244.jpg
@ redrumy3 Whats the temp difference with a fan blowing below your motherboard ?
redrumy your system must be noisy, eh? counted 7 fans? :P
more than 7 in my case :P ( 1 psu fan :P, 1 outside cpu heatsink, 1 inside cpu heatsink, 1 in back of case, 2 on top of case, 1 on ram , 1 cooling hdd, 1 on bottom, 2 on gfx card )
So 11 fans total :D
not really loud tbh but i always have my headset on so that could be why, also use to have a delta fan which sounded like a jet so these fans are much more silent :D
LoL Spawne..AM2.
This is my computer it is about 2 years old now.. so I'm close to building a new one hopefully I will be build a water cooled rig sooo the build log will be in here if i do but this is my Air pc
http://i240.photobucket.com/albums/f...s/IMG_0121.jpg
http://i240.photobucket.com/albums/f...s/IMG_0122.jpg]
Its because of his Gigabyte or MSI? mobo, same thing happens with my mate!
:P
Casing looks awesome as always tommy, the soft flash from the camera really makes the nickel shine. But yours looks like it has no dust issue.
No case atm...
Not so shiny this time, but i like it ;)
http://www.abload.de/img/bild1xf6.jpg
Well, i cut a old 120mm fan in the middle. So i have only the Part thats needed for the screws ^^
