Did you read Warboy's post?
You might be on to something
http://www.xtremesystems.org/forums/...postcount=2205
I did read it. If this is true, it's pretty disappointing and will probably make me steer clear of Asus products again (both my Mobo and GPU are Asus).
I just got in the balance of parts to build my LC rig on this board, and now we find out that they're pretty much discontinued, which is probably why we're not seeing any action on the bios.
Anyway, if this mod salvages it, great! If not, I might have to check out the DFI's.
i currently have that "issue" too.... no idea what it is.
bios 907..
Warboy, you wrote 'discounted';
did you mean 'discontinued' ?
if so, im pretty upset with asus on their decision... :slapass:
i have a feeling my next board will be a DFI like many others on this forum have said.
Well I run 4 sticks of Crucial Ballistix PC-8500, and they work just fine.
The BIOS has a lot of options that has an effect on the ram tho, so if you post your BIOS settings (from Extreme Tweaker) using the format posted throughout this thread then you'll probably get some hints as to what settings you should try.
Nice. This worked perfectly. I am also seeing less voltage for the CPU to hold the same clocks. This is outstanding. Now to figure out all these RAM timings...
Stilt, fantastic job, thank you.
End of life product ? They will come with a new revision proppably.. who knows. It's the same as it was with X38 DQ6 , they found to solder EPU on the PCB as a great HW revision. Maybe Asus is planing something tiny too
How does this Rampage BIOS do with 8GB of RAM?
Discontinued is to be expected: The Maximus Formula is a limited edition board.
Quick question, got broken maximus SE around, it shouldn't be a problem to take the chipset watercooling system from that one and put on a no SE maximus?
I emailed ASUS. Hopefully they will make a Rampage Formula version for the MF motherboard.
My email to http://vip.asus.com/eservice/techserv.aspx
I'm not really having a problem. I just wanted to ask if there would be any way ASUS could come out with a BIOS that has some of the options that the Rampage Formula motherboard does. There is a forum about Turn your Maximus Formula into Rampage Formula. I don't want to viod my warranty but I would like the extra you get from the Rampage Formula BIOS. I bought this motherboard because it was a all out gamer/overclocker motherboard, and we haven't seen new BIOS in awhile.
Shawn
I think so, Yes.. You can put watercooling on your MF non SE.. ;)
Hi guys,
I've got a problem again. My overclock isn't prime95 stable.
I've run OCCT mix for 8hrs+ withouth a problem, but prime 95 blend makes my pc reboot after less than 2hrs.
My NB temp does get about 53C, could this be the problem?
My settings are:
Extreme Tweaker
Ai Overclock Tuner : Manual
OC From CPU Level Up : AUTO
CPU Ratio Control : Manual
- Ratio CMOS Setting : 9
FSB Frequency : 400
FSB Strap to North Bridge : 400
PCI-E Frequency: 100
DRAM Frequency: DDR2- 1066
DRAM Command Rate : 2t
DRAM Timing Control: Manual
CAS# Latency : 5
RAS# to CAS# Delay : 5
RAS# Precharge : 5
RAS# ActivateTime : 15
RAS# to RAS# Delay : -
Row Refresh Cycle Time : -
Write Recovery Time : -
Read to Precharge Time : -
Read to Write Delay (S/D) : -
Write to Read Delay (S) : -
Write to Read Delay (D) : -
Read to Read Delay (S) : -
Read to Read Delay (D) : -
Write to Write Delay (S) : -
Write to Write Delay (D) : -
DRAM Static Read Control: disabled
Ai Clock Twister : strong
Transaction Booster : enabled - 0
CPU Voltage : 1.4V
CPU PLL Voltage : 1.56V
North Bridge Voltage : 1.55V
DRAM Voltage : 2.10
FSB Termination Voltage : 1.44
South Bridge Voltage : 1.075
Loadline Calibration : enabled
CPU GTL Reference : 0.63x
North Bridge GTL Reference : 0.67x
DDR2 Channel A REF Voltage : auto
DDR2 Channel B REF Voltage : auto
DDR2 Controller REF Voltage : auto
SB 1.5V Voltage : auto
If indeed there is any benefit to this rampage bios, why wouldn't asus just make the changes in the maximus formula bios to match?
Isn't the SE the version Warboy has? Anyway, I didn't think there was any differentiation in the MF with regards to Asus since they both use the same bios.
