Originally Posted by
kup
Antec 900 Case. 2x120mm TriCool fans on High @ front. 1x120mm TriCool fan on High @ Rear, 1x200mm TriCool fdan on High @ top. Side panel off.
Thermalright Ultra 120 Extreme with 2x120mm Sharkoon Silent Eagle 200rpm ~75cfm in push pull, in from NB area, out into 200mm top exhaust.
The way the TRUE is mounted (top to bottom airflow) gets me better temps on the CPU by about 7*c over front to back airflow, but it seems to leave a dead spot around my CPU area, especially caps and vregs and mosfets and all that other kit tucked in there. I'll try to dig out a temp sensor later/tomorrow and measure the temps down in there. I'm also going to gut the case and build it on my bench again, so I can prop up a million fans on anything vaguely warm...! :D
