Originally Posted by slappynutz
I've been doing loads of searches, and am still wondering what the effect of VT tech is on an overclock. I know people recommend disabling it, but whether it's on or off doesn't seem to make much of a difference to me. I'm only running a single OS (Vista 64) but I've read alternately that VT tech will only work in a multi-OS virtualization setup, or that it can also help with individual processes within a single OS.
I've got nearly the exact same setup as gtj, with the following:
Intel D975XBX2 Motherboard
E6600 CPU
4x 1G OCZ DDR2-800 Platinum Rev2
Antec P180
Corsair 620HX Power Supply
Raptor 74G
320G Seagate 7200.10
eVGA 8800 GTX
Scythe Ninja Rev B and Artic Silver 5 (which I needed to modify to get to fit next to the capacitors)
Running at 356FSB for 3.2GHZ with the vCore, vFSB and vMCH at the board stock, and the ram at 4-4-4-15 at 2.04 vdimm (which is also pretty much stock).
My temps seem a little on the high side so I haven't really overclocked much more than that. With Speedfan my temps report for the CPU at 37 idle and 62 under heavy load with Orthos, with the board (chipset) running around 45 idle and 52 under heavy load. Of course in gaming and heavy Photoshop use the CPU maxes out at around 47 and the chipset hits 52. Ambient temps in the room are around 26-27c. (I'm using the Bios and Speedfan "Cpu" figure for the temp ... each core always reports about 8c cooler than the "Cpu" number).
Haven't done anything extra to cool the chipset, other than getting an Antec Spot Cool and running it at low, and my case is filled with Scythe and Nexus fans all running low (quiet trumps speed for the time being).
Just wondering if, when I decide to overclock further, I should really disable VT tech and at what temp range I should begin to worry. I've tried upping the vCore to 1.4 in bios but can't seem to get the CPU stable at 3.4, and figure I'll need to bump up the other voltages a bit.
