It's rated for 2.1v. 2.2v is okay under warranty.
What would it be running at if it's on auto? 1.8v?
Are you pressing the DEL key after the USB had initialized? I use a USB keyboard and it works fine, but I have to wait for the USB controllers to init. I'll see the message "Entering BIOS setup..." and then after the drive detection (including Jmicron) the BIOS setup loads.Quote:
Originally Posted by teowws
yehQuote:
Originally Posted by pr33tz
Which bios is best for overclocking?
theyre all pretty much the same, use 1602
Unless you are running an X6800, when the 1602 won't allow you to fully raise the multiplier correctly....Quote:
Allegedly. ;)
His sig says E6700.
Batch B.Quote:
Originally Posted by ntvh
Seems that your CPU has reached it's limit. I find the blend tests to be way more accurate than running tests with small fft's. I typically test the system with dual prime 95 and custom settings tho.. (imo, it seems to give the most accurate results). Whenever you get a blue screen at whichever setting, then chances are the system is not stable.Quote:
Originally Posted by Georgypie
You can try changing the multiplier to 8 and running the tests again at 400fsb...
I can't believe we have almost identical findings. I'll have to lower my timings next... :pQuote:
Originally Posted by weldzilla
Yeah that's the exact same memory as I have.Quote:
Originally Posted by Pluppo
My first set of this RAM I had to return.
It wouldn't post past FSB 336 1:1, and failed prime 95 at all speeds; even stock.
A memtest86 showed it to have a fault.
The replacement RAM works much better.
Thank you.Quote:
pphx459
They said batch B is run way better than the A. OC easy with MAX Ghz with low Vcore. You are LUCKMAN. Thank you:toast: :D
lol thanks, I did get lucky with this one. My first one was L627A and it did a max of 395fsb..
I actually asked for the L630A.. lol
mine is chugging along nicely
Originally Posted by NghtShd
oh...come to think of it, i was pressing DEL key when the big ASUS P5W-DH screen appears and never after the USB init but i press DEL key when i see my keyboard backlit light up so i was thinking the USB hub is powered up. This is not user friendly , imagine i have to keep watch of the USB init before i can do any thing. Can't think of this happening on my previous experience with other motherboards.
Very nice. :toast:Quote:
Originally Posted by Rattle
So wuts the highest stable oc with that beauty?
Correct. I'm going back to the 1500 series. Though the 1602 had some nice fixes... Except for that multiplier...Quote:
Originally Posted by Yonya
I think the very best OC'ing bios for my setup was the 1305. It is very close and the new bios is staying on my computer. I am pleased with it. Let's face we can swap our bios' til we are blue in the face but til Asus comes out with more and better bios updates we will be chasing our tails. I have not had the oppurtunity to run several different types of mem on my system. I have been a G.skill user for quite some time so I bought for this my first venture into DDR-2 So in that regard my mem choice was based on what had worked well in the past and I had heard good things about the 6400HZ the fact that I got a couple really good sticks is as you all know ......the luck of the draw.
So come on Asus finish this board!!! So it will go down as a great board and not a great disappointment. Even tho' I will tell you I for one am happy overall with my setup..
WZ
I went to the store tonight and got luck with the B ver. Will try when my water blocks arrival. Thank you.:toast: :toast: :toast: :banana: :banana:
Anyone has tested this corsair dominator PC8888 - 1111MHz with CAS 4?
http://www.corsairmemory.com/corsair...8-8888C4DF.pdf
Guys....something strange here: I found a way to get into hardware monitoring...
If you disable USB legacy support...it gets in hardware monitoring just fine...doesnt hang.
I always found it would let me in 2nd time after a reconfiguration of settings...
@ASUS!
time for a new BIOS i say again:
more RAMsettings and configuring Vcore without having to disable EIST/C1E
iLL
I just tested 1703 and it's the same as 1602 :(Quote:
Originally Posted by SKiLL3D
New asus pc probe II dated today if anyone's interested
ftp://ftp.asus.com.tw/pub/asus/misc/...eII_V10405.zip
one simple question?
did asus completly forgot the TRFC issue?...im waiting since 3 months ago...no sucess.
I readed somewhere there is a moded bios homemade (by an XS user) with trfc options, is that true?
