BooStFeD i didnt use my p5wdh fan thing like you did it said for passive cooling only i dont think it would do much anyway with the 120mm.... ive never tested it though
i think everyone should immediately spray the inside of their cases black like me funkflix and i
http://www.xtremesystems.org/forums/...=34877&page=94 check mine
http://www.xtremesystems.org/forums/...=34877&page=97
check funkflix
black rules,,,, you can do white if your case is white,, whatever color your only excuse for not painting is if your case is sheetmetal color on the outside and i know its not
i didnt do the removable mb tray but dosnt matter if you do
Yeah, black interior looks very good!Quote:
Originally Posted by hopper
*Gets out a black spraycan*
Looks great! :up:Quote:
Originally Posted by krueml_
BTW something is missing. A vga maybe...? :p:
I took 30min to change the cablemanagement today and this is how it ended up.Quote:
Originally Posted by septim
before:
http://img244.imageshack.us/img244/2325/img0672db2.jpg
After:
http://img83.imageshack.us/img83/4431/img3399ji8.jpg
The tubing has went milkish though :(
Hey Kruemel... Welche Hi-Flo sind das? benuzt du den O-ring der Hi-Flos oder den des Storm's? oder beide? Storm Rev2?Quote:
Danke.
Steve
Hey Kruemel which Hi-Flos are those? Are you using their O-ring or the one from the Storm? both? Storm Rev2?
Steve
i cant seem them senater cache; which ones?
Please show neons when they work ! :slobber:
More pics, now with a vga :D
http://www.4eweb.de/pc/tj07/58.jpg
http://www.4eweb.de/pc/tj07/59.jpg
http://www.4eweb.de/pc/tj07/60.jpg
http://www.4eweb.de/pc/tj07/61.jpg
http://www.4eweb.de/pc/tj07/62.jpg
http://www.4eweb.de/pc/tj07/63.jpg
http://www.4eweb.de/pc/tj07/64.jpg
I'm using the DD HiFlow fittings at the Storm with their standard o-rings.. :)
krueml nice tubes
oppps double posted.... krueml nice tubes ... again
I´m searching for an pic with the ccls running, but first a pic with the new SilverLightnings:Quote:
Originally Posted by HeUeR
http://www.forumdeluxx.de/gallery/data/500/DSC04543.jpg
I've got to get a better camera :)
http://img292.imageshack.us/img292/6538/dsc05205iu7.jpg
http://img268.imageshack.us/img268/4788/dsc05207af6.jpg
http://img143.imageshack.us/img143/2065/dsc05206rx6.jpg http://img237.imageshack.us/img237/107/dsc05209ts5.jpg
http://img237.imageshack.us/img237/186/dsc05213fw2.jpg
http://img171.imageshack.us/img171/7919/dsc05219ud4.jpg
http://img201.imageshack.us/img201/4530/dsc05204lo3.jpg
Nicely done Rasco. I like the EK res very much.
Thx dude! :)Quote:
The res is awesome. You got like a million options on how to use it (perhaps that's why he calls it the multioption res :rolleyes:). Only con that I've got is the grey fasteners that comes with the res holders. The crylic tube and the Acetal gives it a really clean finish but the fasteners makes it look cheaper. But functionally it's the dog's bollocks :D
man o man, I want that res....petra to the rescue asap. plz
Indeed, the grey fasteners don't look good.. These holders would look better: http://www.aquatuning.de/product_inf...t-ck-50mm.html
Great looking case Rasco!
I myself gonne put the res on the backside of my case, i haven't got enough space left inside.
It will be a lot easier yo fill also.
What is the blue coolant you're using?
Is it Pentosin, it looks gr8.
really clean Rasco, I like your work very much :toast:
True, does those holders fit the multioption res?Quote:
Thanks man :)Quote:
Originally Posted by Zeus
It's just ordinary G11 Pentosin from Petras. :)
You're an angel my Croatian friend :) How's things going with your rig man?Quote:
Originally Posted by marauder16
Nice Rigs Guys!
Hey Krueml_, what case is that ? i know it's a Silverstone but which model ?
Silverstone SST-TJ07Quote:
Originally Posted by Patriote
Thanks!Quote:
Originally Posted by OCFX
I think so, they have the same diameter so it should fit.Quote:
Originally Posted by Rasco
Yep.. it's the TJ07..
