F4 2001
CPU core temp. load @ -1C. Lol
http://img844.imageshack.us/img844/4...nshot021ua.jpg
F4 2001
i need a nice CPu like that!
mi new spi pushing a bit :D
http://img820.imageshack.us/img820/2484/bestspi.jpg
Uploaded with ImageShack.us
1.57v on a 32nm chip, that must be sergio :D
dude u crazy!!!!
try a wprime for next time :up:
wow very nice and vcore is still nice for speed Sergio MAKE THAT 2600K SCREAM . . . :up:
Just recieved my board and got it all up and running on water.
this board has f6 bios and 10 load line cal settings.
got a 2600k what would u ppl do to hit 4.6 ghz 24-7 stable.
not used to this board had a asus p8p67 deluxe board before.
and what llc setting would be best form 1 to 10.
thx in response ;)
decided to do some benches on my stable 24/7 clocks
I2600K@ 5GHz HT
Mushkin Redline Ridg. 2133 C9 2x4GB
2x EVGA 570 vid 0,95 both@ 950/2200
3DM03
http://img849.imageshack.us/img849/1833/50053dm03.jpg
3DM05
http://img51.imageshack.us/img51/2447/50053dm05.jpg
3DM06
http://img101.imageshack.us/img101/473/50053dm06.jpg
3DM11
http://img820.imageshack.us/img820/2053/50053dm11.jpg
cheers to all :up:
Sergio
im on it my friend just upping my little point contribution to my xtremesystems team not too much as i dont bench xtreme and im alone but will do the job :up: im 4th in my country but the 3 above are like 10 ppl putting scores togheter
http://img709.imageshack.us/img709/8775/hwbot.png
LLC between 5 and 7 are the only ones worth using, but LLC6 still has some droop at high load, and while LLC7 doesn't have that droop, both LLC6 and LLC7 have erratic voltage spikes, sometimes going as much as 0.030v higher than what you set in BIOS, at *light* load.
I got my GA-P67A-UD7-B3 board back now, finally. I have tried to overclock with the latest BIOS F4 from Gigabytes website, but it won't boot at anything past 4.9Ghz. I then flashed F3H and i was able to overclock back up to 5.5Ghz and run a few benchmarks. Otherwise the board seems pretty good.
Just a quick question though: is LLC Level 2 a bad idea for a 24/7 overclock?
My previous overclock was 4.5Ghz with 1.285v set in BIOS with LLC level 2, but some people have been saying your shouldn't use LLC Level 2 for a 24/7 overclock.....??
You couldn't do past 4.9 ghz ? Sounds like PLL Overvoltage wasn't working ....
I noticed you said you used F4.
Someone with a UD4 board said F4 wouldn't overclock his chip past 4.4 ghz unless he raised VTT to 1.2v and adjusted VCCSA up slightly. He went back to F3D (or F3B?) and he was back up to 4.8 ghz on all auto voltages (besides vcore).
I know PLL overvoltage worked fine on UD5 on both F3 and F5, but there definitely seem to be issues with F4......
Can do 5Ghz+ here no problem with F4 BIOS, and don't need anymore Vtt than any other BIOS (Stock or lower depending on memory), nothing wrong with it at all as far as I have seen.
F4 no problem at all here:up:
I have flashed to f4 2 times and spent a couple hours trying it but was unable to do the same clocks for benching as before. I tried all the llc's 1-10 but have trouble getting into windows at 5600mhz, not sure how good it is for 24/7 stability, Im taking a break from linx and blend. I finally gave up on f4 and went back to f3h, maybe its my settings that are wrong idk :shrug:
Damn :D
Load temperature?
There's a BIG surprise incoming, get ready!! :D
