Can anybod recomend a 8 Gb kit that will Work with the Asus RE ?
Hi guys,
if all goes well i should be receiving my asus rampage extreme tomorrow,
along with some dominator GT 1866 CL7.
I'm a bit lost on the bios, on my previous mobo, a dfi dk lanparty p45 t2rs+
there was a specific bios that outperformed most others by a decent length.
How does the rex do in this? are there any favorites for certain cpu's or?
It's for the use of an E8600
Thanks in advance!
just got the board
i gotta say i'm impressed with the board not impressed with ddr3 lol
too bad asus put heatpipe crap all over
gonna take some time figuring out everything
gonna take out all the heatpipes n replace all heatsinks
nb idlin @ 53c no good
zsamz,looking forward to seeing some of your results on this board:)
im sure you can do it.:up:
just make sure to post it when you do
Hi thijs :) just tried my elpida on RE. nice experience so far
this is on 0403. can't say if new bios would be better for elpida - no other testing yet.
485x8 / 1:2 / 333 strap
http://i447.photobucket.com/albums/q...32M_11m19x.gif
563x8 / 5:8
http://i447.photobucket.com/albums/q..._32M_9m56x.gif
565x7 / 5:8
maxmem 680MB + waza
faster than 2x1GB (D9GTR) @ 7-6-5-15 = 569x7 to get same time. even 7-5-5-15 was still 566/567fsb.
http://i447.photobucket.com/albums/q...32M_10m59x.gif
Well it seems like no one was interested in this so I fired up my RE and did a comparison myself, the outcome is to no surprise for no one I think.
One of the downsides for the RE is that is tough to maintain a stable 500 bus speed with a 45nm quad then with the EP45T, with the EP45T itīs so easy to run 500 bus, one of the downsides on the EP45T is that I couldnīt run my 2x1 Dominator 1800C7 at their rated speed and with both it was tough to run high ram speed, canīt run stable 1800 and up with 2x2Gb on either of them, seems like Elpida low volt ram is the way to go if one want to run DDR3-1800 or higher I think.
This was done with Windows 7 RC 64bit and with no optimizations, a Q9650 @ 500, 4,5GHz and 2x2Gb ram @ 1600 777 21 1T tRD 8 Strong.
http://i282.photobucket.com/albums/k...tRD8Stro-1.jpg
http://i282.photobucket.com/albums/k...RD8Strongs.jpg
cant do much not too much time i really dont like nb60c and sb45c temps
i flashed to 1202 bios
only ran prime 30 min
i need some d9gts how good are BL2KIT12864BA1608
i got my moded xigmatek 1283 ready for nb :D
whats better to cool the mosfets HR-09 U TYPE1 or Enzotech MST-81
i saw you mod 3oh6 with Enzotech BMR-C1 but i prefer mx2 to thermaltape
thijs: board came with 501 bios 1202 is much better
wow nice timings and clocks.. i just started playing with rma replacement kingston elpida hyper 2x2GB - ignore the times just finding 32m stable points
Pretty good for 2x2GB Kingston 2000C8 dual channel @DDR3-1900Mhz 8-8-8-24 1T for single Super Pi 32M at least. As expected needed slightly more NB and vdimm voltage compared to same memory frequencies for single 2GB module testing.
2T vs 1T - memtest86+ v2.11 reported bandwidth difference was 6953Mhz vs 7210Mhz.
2T
http://fileshosts.com/intel/Asus/Ram...1m16s062ms.png
http://fileshosts.com/intel/Asus/Ram...mv/everest.png
1T
http://fileshosts.com/intel/Asus/Ram...1m11s140ms.png
Didn't have to touch tRTR_S/RTR_D and tWTW_S/WTW_D timings at all from auto :)
@DDR3-2042Mhz 8-8-8-24 1T
At same vdimm 1.67006v bios validation @DDR3-2042Mhz 8-8-8-24 1T
http://valid.canardpc.com/cache/banner/595043.png
http://fileshosts.com/intel/Asus/Ram...cpuz_valid.png
2x2GB Kingston HyperX DDR3-2000Mhz CAS8 (Elpida Hyper)
Dual Channel @7-7-7-21 1T
Seems 7-7-7-21 timings are easier to scale than 8-8-8-24 for this memory on Asus Rampage Extreme. DDR3-1952Mhz coincidentally is the highest memory frequency I've managed for Super Pi 32M on Asus Rampage Extreme so far. My Micron D9GTR/Samsung HCF0 seem to top out around 950-964mhz for 32M Pi.
Also 1T gives approximately 270MB/s more memtest86+ v2.11 memory bandwidth than 2T at same memory frequencies in dual channel mode.
Max CPUZ Validation @DDR3-2026Mhz 7-7-7-21 1T at 1.68331v bios
http://valid.canardpc.com/cache/banner/595524.png
Max Super Pi v1.5 & v.16
@DDR3-1952Mhz 7-7-7-21 1T at 1.68331v bios
http://fileshosts.com/intel/Asus/Ram...0m47s359ms.png
http://fileshosts.com/intel/Asus/Ram...0m46s672ms.png
Everest Ultimate Bandwidth
System:
- E3110 Q750A158
- OCZ Vendetta 2 Air
- Asus Rampage Extreme 1104 bios
- 128MB Gainward FX5200 PCI
- 3x 2GB Kingston HyperX T1 DDR3-2000Mhz CAS8 Triple Channel kit (KHX16000D3ULT1K3/6GX) - using 2x2GB of the kit
- 1TB Samsung SATAII
- Pioneer 216 DVD-RW
- 1KW PCP Cooling SLI
- WinXP Pro SP3 nLite fully updated
hello with my config windows 7 build 7229 x64 q9550 c1 467 fsbx8.5x sapphire hd 4870 pcb blu 512mb corsair dominator 2x1 1800@1868 7 7 7 20 and rampage extreme(bios 1202) i test it for 2 hours with prime95 but after a few hours that i use the pc the system crash with this blue screen http://www.trucchetti.com/wp-content...en-windows.png thi is my settings:
Extreme Tweaker
Ai Overclock Tuner: Manual
OC From Memory Level Up: Auto
FSB Frequency: 467
CPU Ratio Setting: 8.5
CPU Configuration
C1E Support: Disabled
CPU TM Function: Disabled
Max CPUID Value Limit: Disabled
Vanderpool Technology: Disabled
Execute Disable Bit: Disabled
Core Multi-Processing: Enabled
CPU Clock Skew: Delay 300ps
NB Clock Skew: Delay 200ps
FSB Strap to North Bridge: 333
PCIE Frequency: 101
DRAM Frequency: 1869
DRAM Command Rate: 1N
DRAM Timing Control: Manual
1st Information: 7-7-7-20-6-82-12-6
CAS# Latency: 7
RAS# to CAS# Delay: 7
RAS# Pre Time: 7
RAS# ACT Time: 20
RAS# To RAS# Delay: 6
REF Cycle Time: 82
WRITE Recovery Time: 12
READ to Pre Time: 6
2nd Information : 8-7-6-4-7-4-7
READ to WRITE Delay (S/D): 8
WRITE to READ Delay (S): 7
WRITE to READ Delay (D): 6
READ to READ (S): 4
READ to READ (D): 7
WRITE to WRITE (S): 4
WRITE to WRITE (D): 7
3RD Information: 23-8-1-8-8
WRITE to PRE Delay: 23
READ to PRE Delay: 8
PRE to PRE Delay: 1
ALL PRE to ACT Delay: 8
ALL PRE to REF Delay: 8
DRAM Dynamic Write Control: Disabled
DRAM Skew Control
DRAM CMD Skew on Channel A: Auto
DRAM CLK Skew on DIMM A1: Auto
DRAM CLK Skew on DIMM A2: Auto
DRAM CTL Skew on DIMM A1: Auto
DRAM CTL Skew on DIMM A2: Auto
DRAM CMD Skew on Channel B: Auto
DRAM CLK Skew on DIMM B1: Auto
DRAM CLK Skew on DIMM B2: Auto
DRAM CTL Skew on DIMM B1: Auto
DRAM CTL Skew on DIMM B2: Auto
Ai Clock Twister: Auto
Ai Transaction Booster: Auto
EPU II Phase Control: Auto
CPU Voltage: 1.468
Load-Line Calibration: Disabled
CPU PLL Voltage: 1.577
FSB Termination Voltage: 1.404
CPU GTLVerf (0): +40mv
CPU GTLVerf (1): +40mv
CPU GTLVerf (2): +40mv
CPU GTLVerf (3): +40mv
NB GTLVerf: +60mV
North Bridge Voltage: 1.603
DRAM Voltage: 2.067
NB DDRVref: Auto
DDR3 ChannelA Vref: Auto
DDR3 ChannelB Vref: Auto
South Bridge 1.5 Voltage: 1.577
South Bridge 1.05 Voltage: 1.100
CPU Spread Spectrum: Disabled
do you help me with this problem? excuse me for my english i'm italian
could someone please help me.
i was wondering if anyone has successfully used this
ram with this board?i have 8 gigs of it and want to
get this board.dont really care about how it OC's
just want to be able to fire up the board when
i get it.ill get some good ram later. thanks
http://www.zipzoomfly.com/jsp/Produc...dlist=celebros
the 1GB sticks are on the QVL,so im hoping these will work too
it should work, i haven't seen anyone report of problems of not booting with 8gb of memory. but chances are, i doubt anyone on this forum with a RE will overload the board with 8gb memory of those specific model. this boards for high bandwidth and tight timing, not high capacity. you should try it out and let everyone know how it goes :up:
as for my question, does anyone get a hard disc detection error during boot up? i'm getting this error every time, but it seems everything is working fine. it says something along this line during the bios boot screen:
what needs to be changed in bios to fix this error msg?Quote:
Marvel adapter - BIOS xxxxx
initializing...
No Hard disc is detected
Maybe hook up a HD to that controller ? or Disable the Marvell controller in the bios...
Donīt know if those particular Doms work but just look at the spec, I donīt think itīs gonna be any problem to run 1333C9, if OC, hard to tell.
I have 4x2Gb of Crucial Value 1333C9 (Micron D9KPT) and thereīs no problem with those @ 1333C9, I can run them at 1600C8 @ 1,80v also.
testing 2x2GB elpida on vista 64
quite interesting result for vNB.. :D
0403 BIOS / 450fsb / 1:2 / 900mhz / CL7 / tRD6
vDIMM 1.51V set / vNB 1.40 set / (NBGTL/skews/vREF auto)
Prime Blend custom 2048-4096K (mem 3.7GB)
http://i447.photobucket.com/albums/q...3_Blade2x2.gif
Awesome cheapseats as always :up:, this makes me want some OCZ Blade :yepp:
just pulled the trigger,and bought the REX:D
got it for 219$ and then 50$ rebate from ewiz
169$:up:
Nice :up:, one more proud Rampage Extreme owner. :yepp:
I suppose that you gonna pop in your magic chip into this RE, it should be interesting to see if it performce better with the RE then with your UD3.
The only thing thatīs missing is some nice ram sticks to pair with the above.
Maybe this one, Super Talent Project 1800C7, itīs only 69,99$, 40$ lower then Newegg and according to Hardware Canucks they are pretty good, hereīs the review.
Happy haunting.
