those will kill your loop, and they use the same powerchips as any1 else, the mushkin accent is much better, since it wont kill any parts
my q9550 is @ 3.915 and 1.48-1.51v is that to much?
k thanks , ill have to buy o.s though since mushkins aint available in australia. :(
i noticed that u only have them running at 1141mhz? were u able to run them at 1200mhz stable? see i really want 1200mhz this time.
also is 996619 the only decent batch ? or which should i look out for? theres quite a few.
thanks adya.
look at my PL :D if i loosened to pl8 i would easily reach 1200, the divider im at now only allows for 1141 so I tightened the PL to increse performance. once it gets colder (once summer is over) i will be seeking higher FSB and higher ram clocks ;) then i will loosen the pl up again
trust me this ram loves this board and vise versa, its a match made in heaven as far as 2x2gb sticks are concerned. 996619 is a great batch if you can find that but the redlines are good also. any mushkin 2x2gb kit labeled 2.0-2.1v has the powerchips so they are pretty much all good
ok , i just go these on ebay.
Mushkin ASCENT DDR2 1066 4GB (2x2GB) XP2-8500 996619
$240 aud including postage. more than i wanted to pay but hopefully worth the price hehe
Got a question I know if you want to do X-fire you have to use slots 1 and 3 but if I have a single card can I use the 2nd PCI-E slot?
yah u can use the middle slot for 1 card it runs the same speed as the top slot, and u mean the 2nd 16x slot slot pci-e#3 right not the 1x thats pci-e #2
Does anyone else notice on this chipset that when you insert a CD/DVD the OS pauses for like 2-3 seconds. Anyway to stop that?
yah, it wont do the pause with the dvd drive with native IDE mode, dont use the jmicron for an HDD
they yellow ones
I've been having problems with running just 1 4870x2. if I use AA I can only use 2x and 4x anything above 4x and games will not load. it doesn't matter what driver set I use. I installed an extra 500GB hard drive and it does the same thing with a clean install of vista. I've tried both of my 4870x2 and the result is the same. I know it's the board because if I use a friends P35 it can use all AA levels.
edit: the cpu is runing at stock 3.0 and the ram is running at 800mhz. when I run 4X I get massive video corruption.
Hey people is there any reason i should get a DFI x48 board over a P45? I was kinda going for the DFI X48 LT but people suggested me going for a P5Q Deluxe instead, which one is better?
