Well I switched to Vista x64 and added two more 1GB sticks. I am using 4 x 1GB now with zero issues. I am using two kits of Mushkin 996523.
When I get the BX2 I plan on putting high quality thermal paste like I always do on the NB & SB. How are the sinks attached on the DX2 it doesn't look like standard plastic pins.
I've been waiting for Auzen Vista x64 drivers. Have they finally released it?Quote:
Originally Posted by Blacklash
Hi guys, Is there anyone who tested max FSB with QX6700 on this board yet ?
Thanx for all
regards
Fits perfectly. I had to raise my fan a bit so that I could populate the first dimm slot, but yeah, it fits in there just fine. This info is also on the scythe site.Quote:
Originally Posted by cursivearmy1
Wire retention bail. Takes about 5 seconds to take them off and another 5 to put back on.Quote:
Yep. At least back to 2333.Quote:
Originally Posted by Zucker2k
Not last I checked. I have been using MS HD audio with Vista's processing since I switched and haven't altered my sig.Quote:
Originally Posted by Pixie_marj
For those that aren't aware of the sound changes in Vista:
http://www.extremetech.com/article2/...1931917,00.asp
Has anyone had a problem with this board killing ram? It seems the 2nd blue slot is killing ram like its job for me. thats the 2nd stick of dominator c3 that its killed, the other one runs fine.
Vmch was at 1.5v and the fsb was 1.4v 3-4-3-7 2.4v just dropped the last timing by 1. What is with this board its a new board too as I had to buy a new one because last one had bent pins after. hmmm
the supposed dead stick will still boot, but soon as I use memtest it racks up about 1000 errors right after it loads and starts running the test.
It fried one pair of Crucial Blastix PC8000 at 2.32v 400Mhz 3-3-3-8 for me after running 2 or 3 weeks.:(Quote:
Originally Posted by ChaosMinionX
However, I think it is the defective ram sticks that fail over time.
The new replacements just work fine under the same condition.
You need to measure Vdimm by a multimeter if you're really skeptical of the board. There is a post in this thread showing how. But, I don't think it's the board. If it is the board overvoltage, you have no chance to boot with the defective ram again.
I think it is the memory manufacturers to blame. They simply bin the D9 chips too aggressively, leaving less room of tolerance.:slapass: On top of that, you overclock them.:)
thanks god for your sig i was still waiting for my graphics card to arrive on my doorstep then i saw that your sig had a 8 meg pci graphics card so i found THE ORIGINAL Radeon PCI all in wonder and plugged that sucker in and started setting up my computer while i wait for the graphics card to come in on tuesday.Quote:
Originally Posted by heikis
Originally Posted by GPSeek
I dont overclock the ram though :D thats the one thing I run stock
GPSeek, dude we seem to have the same setup. May ask how u got yours stable at 3.6? I've been breaking my balls but so far no joy. What are your BIOS settings for that OC? Cheers mate.Quote:
EDIT: ChaosMinionX or yourself, it seems your rig is similar as well.
Originally Posted by J@mmer
1.4v vCore
1.5v vMCH
1.4v FSBv
ummm enhanced power slope on.
However 1 of my sticks of memory is dead :mad:
Cheers bro, but still no joy. :( I'm starting to think my CPU is a dud. Anyone else running a Xeon made in the Philipines? Batch number starts with a 7 rather than an L.Quote:
Sorry to hear about your RAM, hope this is not a common occurence with the Axe2.
I'm getting really pissed off with this rig, no matter what voltage i feed the CPU (even 1.6V in BIOS) I cannot get it to 3.6
With my QX6700 I could go to 390 FSB, but my temp were reaching 70 (on Intel TAT), so I turned it down to 350 FSB. But it was no stable, so I decided to run at 266, and instead turn up the multiplier to 13x. Also, at 350 it needed 1.5V, and I was afraid the QX6700 will not last long, so I run at stock.Quote:
Originally Posted by pepinorang
I run my memory at 800 (266:800 ratio).
How did your QX6700 run?
It seems that thus it is… too many guys saying the same in many forums:mad:Quote:
the damn slot 3#...This is the reason for which I use value ram and very low voltages and defaults timings...:(
My xeon is L631b115Quote:
Cheers bro, but still no joy. I'm starting to think my CPU is a dud. Anyone else running a Xeon made in the Philipines? Batch number starts with a 7 rather than an L.
I think it killed one stick of my Ballistix too.
The strange thing is that when I put it in I don't get 3 beeps but hdd light keeps flashing instead and nothing happens.
The other stick used to boot at 1.8v, but now i need to use cheap ram to get into bios increase the voltage and only then it boots.
for how long have you ran your combo? I have ran my combo for a month or so and none of my mem has died.Quote:
Originally Posted by azzido
- I can't wait until I get this board with my e6700. (proven clocker to 3.7)
- So what are safe slots to put my ram in?
- Also I noticed it has 2 cpu power connectors on it, my OCZ GamXstream 850w has 2 cpu connectors do I connect both to the mobo or use the adapter?
I have been running this combo for about 5 weeks now.Quote:
I tried my "dead" stick on infinity 975 and it posted at 2.2v just fine. I will try to flash different bios and test if that works.
thanks all (especially gtj) for your help. everything is up & running great!! my first build & it was relatively painless. running at 3.0ghz now. I will get it up a little more, when i have more time to test it.
the only thing im noticing is my computer is randomly coming out of sleep & then getting hung up with no video... I think this is a Nvidia driver issue (supposedly fixed in latest bios). but im not sure why my machine is even trying to come out of sleep mode.. nothing like getting woken up at 3am to my computer booting up... with all those damn blue led fans in there, its like im getting visited by a ufo.
Bummer, I was hoping you have some sort of beta driver you're willing to share.Quote:
That's the only thing that's keeping me from upgrading to Vista x64, but I'm not in a hurry either.
Thanks for the link. Nice reading.
No problems with any slots here. I use 1 & 3 out of habit.Quote:
Leave the power connectors ganged together so you have the 2x12 main connector and the 2x4 cpu power connector and use them both. Also if your video card doesn't have it's own pci-e power input, plug 1 of the 1x4 molex "hard drive" power connectors into the socket right behind the LAN connector on the MB.
Got a cat that's playing with your mouse? :)Quote:
Originally Posted by argylesocks
