Just recived a Opteron 170 CCBWE 0551UPMW any results on them?
...170 CCBWE 0551UPMW will be here for testing today.
I have an Opteron 170 0550 UPMW on order from Max2 Multimedia here in Canada.
From what I am reading the 0550 VPMW is much better.
Is it worth trying to get one over the 0550 UPMW or is the 0550 UPMW a decent overclocker as well?
I will be happy with 2800 at anything near stock Vcore.
I have a 170 UPMW 0550 *408L and its currently priming 2800 @1.45 vcore.
komplett.no yes.Quote:
Originally Posted by Clint
Are they that bad?`
Hi guys, i have a opty 170 0550 UPMW, 043 batch, i had ir for several days @ 2850mhz stable, and now all of a sudden it doesn't want to boot to windows @ that speed, now only works @ 2800mhz and it's not fully stable. I dont know what's goin on here, but somehow I feel that my cpu doesn't like my RAM or it's the board dying slowly.
Any opinions guys?
I dunno really, but coz I've read so many reports about the 0550 I was hoping for that one.Quote:
Originally Posted by Nightprowler_77
Post your results here.Quote:
Cause of work I won`t be able to test mine until tomorrow
not tested as yet just a quick info post. All signs look good though.
http://img128.imageshack.us/img128/8206/opty260dv.jpg
http://img102.imageshack.us/img102/7718/dsc002624dd.jpg
Originally Posted by turbox997
depends on batch and stepping and probably your cooling....but prolly around 2.4-2.7
http://img135.imageshack.us/img135/9126/opty270ue.jpg
still to test stabilty, but looks good on standard air cooling :woot:
Well, I have the same one as the one in the picture. So far 2.7ghz with 1.3v 8hrs prime. Temps are ~30c idle and ~45C full load. Room temp is around 74F. This chip runs slightly warmer than my other two. I was getting around the same temps with 1.475 on my tpmw. Tried 3ghz with 1.5 but if failed prime fairly quickly. I'm working on trying to get my memory straight before I try to go any higher. I have to say... This thing is da bomb :woot:Quote:
Originally Posted by Rufus7
Originally Posted by Punkas
same here... 2700 @ 1.425 double sp2004 stable on a 165 and now it needs 0.025 more! but I wont give in... burn in like that for a while!
the temperature is rising unbelivebly! a few days ago I wound't even leave home without a couple sweat t-shirts and a jacket today im wearing a t-shirt only!
and i feel the CPU felt that one too!
Ok, finally at home and holding a CCBWE 0551 UPMW in my hands.
time for rip open and plug it in...:D
Isn't it something I must install/uninstall when going to dual from single core?
..i recall something about API or somtin'
anyone that has a clue?
Graham, mine still does the same clock as yours but at a lower voltage. :p:
Follow this for Dual Core
http://www.xtremesystems.org/forums/...ad.php?t=81429
anybody know about this:
0546xpmw
do a search, but yet, i had one that did 2.6g on stock volts with my shuttle air (resonable, but not best)Quote:
Originally Posted by Grinch
preliminary report on that CCBWE 0551 UPMW:
fails @ 2.5 stock volts on core 0
fails @ 2.7 on 1.45 volts
..will play some more and then send it back...I had made my mind up already, if stable @ 2.7 on some 1.4v I will keep it.
I'll stick with my 146'er I think.
I have a CCBWE 0551 VPMW 165, and it will do 2.7 @ 1.39v (1.425 in bios) but I'm water cooling, it also does 2.8 @ 1.568V...What are you cooling with the Thermalright? I'm on water.Quote:
see sig link :DQuote:
I have got an Opty 165 with CCBWE 0551WPMW stepping. Anybody else with that stepping here?
i have one too, but no testing yet
PS: dont pay attention to my sig
Originally Posted by eva2000
WOW!
Why do you run OCCT with a dc?Quote:
OMG.....I am happy right now w/ my 170 0546xpmw...been priming for 3 hours now at 1.312V and 2.6Ghz....no probs at all! will try for more later and post some screenies!
