>CPU: Dothan 1.73 gig 533 FSB - $200
i recommend a used cpu, they are much cheaper. if you want me to find one for you, just pm me and i'll help you look around
>MOBO: Asus P4P800-E Deluxe - $118
i'd personally go for the p4p800se
>RAM: (512x2)OCZ PC3200 Platinum EL Revision 2 - $160
For thsi price, you might as well get two of these:
http://www.newegg.com/Product/Produc...82E16820231036
250mhz with cl3 (maybe cl2.5) shouldnt be hard for them, even on the voltage-limited asus boards. i just bought one of them and will post resuslts from my dad's ultra-d based a64 setup.
>VIDEO: BBA X800XT AIW - $280
The agp aiw x800pro cards can be unlocked to 16 pipes :). i'd recommend one of those.
>Cooling: Arctic Cooling Freezer 4 - $28
I recommend the 7000alcu, its very easy to install and is quiet
