I can move the pump out a bit to fit in a sound card. I just don't have a sound card. I did have the AC 64 but im going for complete silence with a fair overclock.
That hose that disappears behind the big wires there, is that a kink I see back there?
:eek: Yeah, I think so too. Dude you should check that out. Any way you can go straight from the rad to the block or would that be too sharp?Quote:
Originally Posted by SparkyJJO
:EDIT: How about also trying to shorten the distance between res and CPU block.
Btw, Foxy_PT, that rig looks awesome.
Usama aka Ferrari Freak
Yea thanks I did see that. I fixed it with the spring like material around the tube works great. I tried going the direct route but it does not work with that tubing I bought. Need to find more flexible stuff.
I haven't had any problems. The case has good airflow in addition to the WC.Quote:
Originally Posted by Rabidmoose171
DE
My renewed water cooling setup... nothing special.
http://shrani.si/thumbs/picture001oh9a.jpg http://shrani.si/thumbs/picture002oha4.jpg http://shrani.si/thumbs/picture008oha5.jpg http://shrani.si/thumbs/picture013oha7.jpg
A pic of my old rig..
http://www.4eweb.de/pc/wm051.jpg
And my sweety :D
http://www.4eweb.de/pc/bichrom01.jpg
krueml_, looks pretty... and what is inside?
It was a AMD XP 3200+ @ NexXxoS XP Rev.2, 9800SE @ NexXxoS GP2X-A, A7N8X-E Del. @ NexXxoS NBX-N.. rad was a Cape Cora 642 and pump a Laing DDC-1T @ watercool top..
My very first WC setup thxs to everyone at XS for helping :toast:
Some pics 4 U :D
http://i137.photobucket.com/albums/q...8/P1010158.jpg
http://i137.photobucket.com/albums/q...8/P1010160.jpg
http://i137.photobucket.com/albums/q...8/P1010155.jpg
http://i137.photobucket.com/albums/q...8/P1010153.jpg
I can not figure out how to turn the flash off this dumb camera :(
Looks good BooStFeD, except at the inlet of the pump looks to be a partial kink, not bad but it could be restricting flow. Kind of a tight bend.
Thx for the kind words. I just noticed the same kink after posting these pics :) . When i was trimming the tubing i cut too short :slapass: . For now i put a small zip tie to help bring out the kink.Quote:
nice :D 6 fans...it has real difference to 3 fans?
ps: even tho its not a big deal like a kink or anythign at all,
the thumscrews on your cpu block are upside down. tadah! so like whenver you doing a remount or swapping cpu chip, cna flip em over
Some Pics of my watercooled Systems:
http://www.forumdeluxx.de/gallery/da...m/DSC04694.jpg http://www.forumdeluxx.de/gallery/da...m/DSC04695.jpg
http://www.forumdeluxx.de/gallery/da...m/DSC04687.jpg http://www.forumdeluxx.de/gallery/da...m/DSC04680.jpg
http://www.forumdeluxx.de/gallery/da...m/DSC04670.jpg http://www.forumdeluxx.de/gallery/da...m/DSC04664.jpg
http://www.forumdeluxx.de/gallery/da...m/DSC04662.jpg http://www.forumdeluxx.de/gallery/da...m/DSC04655.jpg
http://www.forumdeluxx.de/gallery/da...m/DSC04090.jpg
http://www.forumdeluxx.de/gallery/da...m/DSC04748.jpg http://www.forumdeluxx.de/gallery/da...m/DSC04747.jpg
http://www.forumdeluxx.de/gallery/da...m/DSC04751.jpg http://www.forumdeluxx.de/gallery/da...m/DSC04770.jpg
http://www.forumdeluxx.de/gallery/da...m/DSC04769.jpg http://www.forumdeluxx.de/gallery/da...m/DSC04771.jpg
http://www.forumdeluxx.de/gallery/da...m/DSC04775.jpg
Nice setup MFlox, welcome to XS, be it that this is your first post.
thx ;)
Some more:
My CM Stacker
with Revoltec DarkBlues:
http://img288.imageshack.us/img288/3485/dsc04351gs8.jpg
with Aerocool SilverLightnings:
http://img409.imageshack.us/img409/1817/dsc04360vx8.jpg
my "old" MSI 6800GT
http://www.forumdeluxx.de/gallery/data/500/DSC04752.jpg
and the new Asus 7950GT
http://www.forumdeluxx.de/gallery/data/500/DSC04646.jpg
http://www.forumdeluxx.de/gallery/data/500/DSC04644.jpg
http://www.forumdeluxx.de/gallery/data/500/DSC04647.jpg
http://www.forumdeluxx.de/gallery/data/500/DSC04650.jpg
http://img264.imageshack.us/img264/1474/simg3035uy4.jpg
http://img477.imageshack.us/img477/4093/simg3038ej0.jpg
http://img527.imageshack.us/img527/3630/simg3039ml1.jpg
http://img527.imageshack.us/img527/7040/simg3040ar1.jpg
http://img527.imageshack.us/img527/3122/simg3041gd8.jpg
http://img164.imageshack.us/img164/760/simg3043ad8.jpg
http://img46.imageshack.us/img46/3784/simg3044kd0.jpg
http://img212.imageshack.us/img212/1250/simg3047tc0.jpg
http://img129.imageshack.us/img129/6919/simg3046zs9.jpg
the pics aren't very good :( my cam have probs with the white light.
I'd love to see some results for a 7900gt(X/O) card on the memory for that heatkiller cooler :) cant find a review where they check difference in OC tough.
Very nice pics, MFlox and o$$i.
Those Heatkillers are one of the best looking blocks around.
Wilkommen bei XS, BTW :welcome:
@ Vandread
looking @ my sig ;)
@ jupiler
thx :)
Great Pics and Great Sys, o$$!ram ! :up:
Hey Flo, welcome to XS!
Took some more pics. Moved a fan and changed some wiring. Hope you like :D .
http://i137.photobucket.com/albums/q...8/P1010106.jpg
http://i137.photobucket.com/albums/q...8/P1010107.jpg
http://i137.photobucket.com/albums/q...8/P1010109.jpg
http://i137.photobucket.com/albums/q...FeD248/WC3.jpg
http://i137.photobucket.com/albums/q...8/P1010175.jpg
Can't you just drill two holes in the top of your case big enough to take a tube so you clould flip your rad over and have the side panel back on?
Just a thought. ;)
