ANY brothers using the Swifttech Apogee CPU block on this MB. Can tell me whether it fits?
I've got the Apogee GT's. Fits perfectly.Quote:
Originally Posted by pa9797
Is anybody having their multiplier changing back and forth? My E6400 runs at with the 6x multiplier until I use a cpu intensive program with the latest bios. I have all of the options disable in the bios unless I forgot to shut something off.
http://valid.x86-secret.com/show_oc?id=174061
Old news. :)Quote:
Originally Posted by badboy
Disabling C1E in BIOS doesn't actually disable it on the processor. Never has. BIOS bug already reported to Intel. You can turn it off from Windows with RmClock or Everest (but it won't stick after a reboot). Few people noticed until CPUz 1.39 came out. Previous versions were actually reporting the max multiplier not the actual.
It says with the CPUz 1.39 that it is running at 3.5ghz all of the time. But with CPUz 1.39.1 it says different.Quote:
Originally Posted by gtj
But again, if I deside to go with aircooling.
Does the Scythe Ninja fit`?
Scary hot! :D Highest post reached was at 380mhz but windows would lock up as soon as any load was put on it. Lowered fsb to 334, cpuv to 1.5, mchv to 1.6, ddrv to 1.9 & fsbv to 1.22Quote:
I ran orthos last night, (Torture Test ran 8 hours, 38 minutes 24 seconds - 0 errors, 0 warnings.) Highest temp reached under coretemp was 48*c /TAT= 60*c.
All using my $12 special Sunbeam silent wisper HSF:) I may try a better HSF like the ENZO as I dont think a tuniq will fit in the case.
I would like to know this also as I plan on getting a BX2 and I have that cooler.Quote:
Originally Posted by Nightprowler_77
The Tuniq fits perfectly. :)
listen to gtj. he knows what he's talking about.
C1E does not get disabled even if you set it to disabled.
download rmclock and you will see that it is still enabled in windows.
once you disable it and hit apply, you will see your clock speed get set to what it is in bios.
Do you think C1E can cause instability issue if not correctly disabled? EIST Speedstep is off, thats the thing that changes the voltage while idle/load but C1E if it only changes your multiplier it shouldnt be a problem for stability ? You only waste voltage for lower speed but you save a bit of power consuption because of the lower Mhz even if you have the same vcore.
Originally Posted by shimmishim
Yup. C1E is definitely enabled even if it's disabled in the bios. :rolleyes:
For Badaxe 2 What Is The Big 4 Pin Connector For? Can I Use It For Fan Or Does It Have To Be Connected To The Psu?
you can use a regular 3pin fan there.Quote:
Originally Posted by purplehaze
C1E drops the multiplier to 6. But what about voltaje? Drops to a fixed value or is it dinamic acording to the vcore set in BIOS? Both P5W DH and DFI iCFX3200 only drop the multiplier when C1E enabled, voltaje is the same all time.
Okay guys I'm getting this board with a e6700, anything I should know before hand?
no no no not that i meant the 4 pin connector by the i/o plate the big wide one that resembles the regular pata connector power pin.Quote:
Originally Posted by heikis
C1E will change multipler AND voltage. As Intel describes it, when both cores go into a HALT state, C1E first lowers the multiplier, then lowers the voltage. When they come out of HALT state, C1E raises the voltage first, then the multiplier. HOWEVER, I have observed that if you've set the core voltage to something other than default, C1E seems to only change the multiplier.Quote:
Originally Posted by shogo_ca
I haven't seen any stability issues related to C1E but that doesn't mean there aren't any.
To the guy (nightprowler 77) that's asking about the Scythe... I have an Infinity fitted to mine. If that fits, the ninja should I'm thinking.
Well, thats it :)Quote:
You mean, this has always been the case in all previous bios versions?Quote:
I was playing around with OC'ing on the weekend and did notice this. I was using CPU-Z 1.9 and thought it was a bug. So it's actually reporting the speed correctly? Another thing I tried was to clock the chip up to 3.6GHz and couldn't manage it, even with 1.55V set in the BIOS. Sure this CPU should be able to manage 3.6??? I even set vMCH to 1.6 and vFSB to 1.5 (i think). Could this have something do to with the C1E feature?Quote:
yes the Scythe Ninja fits
That is an "Auxilary PCI-E power connector" that is designed to give a little additional boost to the PCI-E bus I believe, I would NOT hook a fan up to it, although it probably wouldn't hurt anything, but the fan wouldn't work and you never know...Quote:
Getting slower then expected RAID transfers off the ICH7 measured by HDtach.
3 Seagate 320GB 7200.10 RAID 0, and I'm stuck at almost a flat line 122MB/s, something not right there(burst is 256). BIOS setting, HD firmware, driver? Is this common? It's unacceptable performance. I have seen the ICH7 doing much faster then this, so it's something I need or am overlooking.
