For me it doesn't matter, have tried both slots now for some time and no difference.Quote:
:up:Quote:
Originally Posted by daos
:toast:
:clap:
:rotf:
I agree!
sparx :D
yes I have never had a problem and i traded this board for my p5b deluxe and it was used !
I like it better and gskill is my fav since my ddr 500 UCCC sticks on my dfi ultra-d
Where are the BIOSmodders? We just need tRFC unlocked for RAMissues^^
iLL
There, now I can read which version of Windows is supported. :DQuote:
Originally Posted by DutchBBQ
Is it possible to buy watercooling parts (as suggested in the picture below) for the Asus P5W DH Deluxe from an English speaking site:
http://mips-computer.de/images/p5wdh_full_mounted.jpg
The last time I had an 8800GTX it sent the idle temperature of my northbridge to to 51 degrees celsius when idle thus I have seriously been contemplating watercooling as the solution to both high temperatures in modern graphics cards and its effects on the surrounding components.
It would also keep the PC relatively quiet if I bumped it up to 3ghz again. :p
I dont have any north bridge temperature problems.
It's not so much a problem (it's stable after all) but given it can go as high as 46c during the summer (and it is in the loft area of my house that can get very hot during the summer) I would like to bring it down if possible without adding more noise thus the idea of watercooling seems quite attractive.
You won't get very far with asus bioses. The bios editors that are available all crash when you try to open recent bioses. Also, no one can edit the tRFC into the bios, if it's already coded and is just hidden, then it's possible but no one can just recode a bios with tRFC in it.Quote:
Originally Posted by SKiLL3D
Those things are rated for 40 to 65C and mine usually stays @ 49C or thereabouts.
Ok then that leaves us no choice than to either sell the motherboard, get new memory, or re-program the SPD for the memory itself.
Wow, those are not the best options.
:mad:
Hey guys... upgraded to the new 1602 BIOS and now can't increase the multiplier of my x6800 to 13. Anyone else notice this?
In 1503 I have the multiplier=13 for 3.46ghz, ram at DDR2-1067 for PC-8500 - very fast.
Not sure if they added something that I am missing or not ...
If you mean adding tRFC to the menu then I agree. It might be possible to edit it in such a way that is uses a more conservative tRFC setting so that manual timings work better, however.Quote:
Can confirm this as well. 1602 don't allow mp over 11 to be entered.Quote:
Originally Posted by seanmcgpa
Get your act together ASUS!!
Hmm, I haven't upped the multiplier but with my e6600 with x9 multi, I am sitting at 3.9 with 1.5v rock stable. This wasn't possible with 1503.
http://www.toptenguild.net/pics/pc/oc_430.JPG
What cooling are you using?Quote:
Originally Posted by pphx459
Using water, storm block, with pa 120.3.
what is your batch ver of your CPU? A or B .Thanks:DQuote:
Went searching hi and low, for advice/information on running the P5W DH with Geil 6400 4-4-4-12 UDC. When I tested it I couldn't raise the FSB over 365. What ever I tried, and the memory needed 2.2v to do anything at all.Quote:
I stuck my AW9D-max back in, and the memory is working just fine. Haven't pushed it but have had it at FSB 405 1:1 4-4-4-12 2.1V
The latest bios in the aw9d, which I'm running does have a trfc option, mine's currently at a default 35 in bios. Albeit I realise there's a bit more to it, I wonder if having a trfc option is indeed the answer/solution to some of these ram issues.
Just got to say though that currently P5W DH and Geil 6400 4-4-4-12 UDC is a bad combo choice. For anyone considering.
Limited for choice in Thailand, no mushkin, OCZ, team, Gskill HZ etc, so can I ask is corsair the way to go. Say the 6400 dominator stuff?
Cheers
RLM
What should I have this set to :
MEMORY REMAP FEATURE
ENABLED or DISABLED ?
Cheers
Assuming you're using a 32-bit OS, then you want to have it disabled.
Its a ram timing problem (safty feature)
when you boot at FSB 360+ the asus 975 boards
are more stricter with SPD timmings if your pushing high FSB
so when you set manual memory timings then save and reboot
it no's your ram cant run @ those speeds as its looking at your Poor SPD timings table, so it gives you a black screen
so now it wants you to set auto SPD but the problem now, is your memory is running way slack timmings 5.5.5.15
So the only way to solve it, is buy RAM that has aggrasive timings in the
SPD tables like the teams xtreem,Cellshock, Gskill, and you will boot 400 fsb with manual timings no problem.
i have found this out with my p5w 64 workstation
changed ram to some cellshock PC 6400 and no more 360 fsb bug
can boot @ 420 fsb 1.1 with memory @ 4.4.4.12 @2.1 volts
memory affected will be the crosair range, Geil, some OCZ
hope this helps alot of folks i spent ages trying to solve this.
As I said in previous post quality stuff is hard to come by here. Does the corsair dominator 6400 4-4-4-12 (I think it is), have the same fsb/spd issues with this board? I understand from another thread that corsair tends to work better on the asus boards.
I've got a pw5 sat here, and am contemplating another build for a mate of mine, and don't want to end up wasting more money if poss on the wrong components.
RLM
thanks ;)Quote:
Originally Posted by don_vercetti
yes that corsair will have problems, because crosair program the memoryQuote:
Originally Posted by RLM
SPD table to something like 5.5.5.12 @ 400 fsb
you need ram that says 4.4.4.12 @ 400 fsb in the SPD tables not many ram on market has this
there is no need for corsair to program the memory with crappy timings
thats a myth, that its for compatable reasons
because my ram can boot up with 5.5.5.15 with 1.8 on auto everything and there is not even any 5.5.5.15 timings in my SPD tables to be seen.
