:woot:
CABGE 0536 vpmw WITH AIRCOOLER
i put my rig to outside of house and temp was +4c
cooler is Zalman 7700 CU + 120x120 125cfm fan
here is sp8m time
http://img487.imageshack.us/img487/7050/super15an.png
:toast:
:woot:
here is sp8m time
:toast:
lol! very nice...
what loadtemps did you have with 4°C ambient?
I believe my CABYE has possibly the most horrible core contact so far, IHS removal is looking like an absolute necessity. I cranked up the voltage to 1.6 and just slightly upped the clock speed to 220mhz. 2.2ghz@1.6v with a TT Smartfan blasting at 5340rpm, which is roughly 85cfm, on a copper brick of a heatsink. It's idling at 64C, granted this is an AN8 I have it in right now, but with the latest bios's the temperatures are actually in line with other boards, some people even report them being too low. Sigh.
Edit: Testing it some more, it now has -1C air blowing on it, at stock settings under prime its 44-46C... Took 1.7v to even think about going into windows at 3ghz and the temperature was idling at mid 60's. Here's to hoping it fails prime at stock settings while not having -1C. If not, on to ebay it goes.
@ Spooky, well mine set to 1.55 does 1.584 most of the time so it seems to slightly overvolt is the 240 1T bug still aparent on this board? I dont really want to try because I dont want to have to open up my case again til i got my water to pull the cmos jumper :)
Overvolting i dont mind so much hehe. Wasn't aware of a 1T 240 bug (I'm new to A64's, first build in fact) is that 240 on the RAM or HTT?
Hiya, as i'm in the UK and returning my CAB2E can anyone give me a list of the stepping of CABYE that I should be looks for?
http://home.scarlet.be/~pascpiet/DV/...W_MS@1.47V.pngCode:Opteron 146 CABYE 0540 FPBW
DFI nF4 Ultra-D 702-2 BTA
Puit Cooling -> Full = ~ 39°C
Max Stable -> 3120 MHz @ 1.62V
:love:
Very nice, unfortunately all are sold... :(
Lovely computersmsa! :clap: ,Quote:
Originally Posted by computersmsa
This is what i was looking for. Since my opty 146 CABYE 0540 FPBW is just ordered i hope to obtain such level of results.
Tested mine quickly during my lunch time,Quote:
1M @ 3050 , 1.39v passed :toast:
Now www.komplett.no have 146 at their webshop, 10 day delivery. What stepping will I receive most likely? Anyone know?
Just ordered!
I don't know, i ordered too at komplett.nl.Quote:
Originally Posted by furyfax
I hope/suppose they are new batch, all old stock are sold I guess.
They are CABYE for sure.
Mine cabye 0540FPBW from alternate has also arrived from alternate.de . Totals costs were 160€ with shipment costs. And they have stock. I don't know if they all are caybe's 0540 FPBW but you can try.
Does anyone have already results from this stepping with a dfi rdx 200? And which you should set in the bios.
Dude, that's the same as komplett.se.Quote:
"Antagen leveranstid 10 dagar", which means they have no idea when they actually will show up. I hope you're lucky though!
My CPU is with fan, isn't most likely i get an older stepping then ? I guess komplett.no get their OPTY's from komplett.nl since they are in stock there. Can't take 10 days to ship a CPU from NL to Norway !
idle was around +25c and load was between +40c <--> +50cQuote:
Originally Posted by LoKi2k
wait a second, im posting my 26second superpi 1m result :) and my mem settings...
I got two of these CABYE 0540 FPBW on the way i sure hope they clock well :)
I wanted to buy 1 CABYE 0540 FPBW but the store that sell these cpu didn't answer me when I asked him If they opened all the boxed cpu... They aren't honest... they open the boxed cpu, take the best for them and If you order non pretested cpu you have a bad cpu.
Very bad attitude...
my settings for memory...
here it is
http://img374.imageshack.us/img374/1...etukset4yk.png
sp1m result
http://img286.imageshack.us/img286/9...1msuper0ql.png
:toast:
What BIOS is that you're running?
DFI NF4 I assume?
Well I have ordered before when aitem is marked the same way and then it came before the time. I just hope they are not screwing me!Quote:
Originally Posted by Mats
Originally Posted by KeZzZu
try the super pi 1 M mod1.4
http://users.skynet.be/pt1t/144/1M_3051mhz.PNG with the Cabne 0540
Opty 146 cabbage 0536, my board has a proven fault that it will not work past ~ 291HTT so hopefully when I buy the DRI Expert I should easily hit well past 3Gig
http://i16.photobucket.com/albums/b2...0ne/1M2989.jpg
What is better... CABNE 0540 APMW or CABYE 0540 FPBW?
i have both ...Quote:
Originally Posted by Txaime
CABYE 0540 FPBW -> occt 3ghz 1.39v , full 37°
CABNE 0540 APMW -> occt 3ghz 1.7v , full 46°
(one of the best batch ...)
