1 Attachment(s)
Question on "ALL" Mem LinX Requirement
I currently run my rig with an OC that includes full-featured ops, all the way through four levels of Turbo, that peaks at 5 GHz single core. It's stable and reliable enough to lend confidence to an all-out attempt at full 5 GHz rigging for a qualifying run submission, but I have a question on the requirement for using "All" of the RAM within LinX's setup in a system sporting much more of a RAM load than is the norm for most gaming rigs.
Right now I have 32 GB installed, and after the OS and an 8 GB RAMDisk for Temp files there's usually a bit over 22 GB remaining. With that info, here's a snap of the first iteration of such a LinX setup with my system at 4.625 GHz which may immediately highlight what I'm about to ask:
Attachment 129662
Since there won't be too much more time trimmed off each iteration at full OC, can there be a reasonable ceiling to the amount of RAM used for LinX runs so as not to tie down the system completely for 12+ hours just to generate a qualifying screenshot?...
