Aa work of art, as usual. :yepp:
The trick (and challenge) is to make both ends of a single cable to look like that. Was able to do it on my HX850 about a year ago and about to start again on a AX1200. Sleeving one end perfectly and then covering the other with a single large piece to cover up inconsistencies is the easy way out.
Being a perfectionist and sleeving sucks....
Yes, thats how it should always be done!
And, there is no better sleeve in the world than what MDPC-X sells!!!!!!
I have nothing to add :D:D:D
Ah - I have: And, there is no cheaper sleeve in the world that what MDPC-X sells!!!!!! :D
http://h-2.abload.de/img/pcies5f9v1.jpg
http://img13.abload.de/img/neverendings27z2bq.jpg
What size sleeve do I need to sleeve ALL of the front panel wires into one sleeve? I'm talking about the Speaker, power and reset switches, and the power and hd activity leds.
Thanks NFC :)
Shawn: Yep :)
http://farm5.static.flickr.com/4076/...8eaf55f1_b.jpg
http://farm5.static.flickr.com/4100/...78c8f8da_b.jpg
As you can see above, Crys1s_Gam3r has kindly taken on the task of sleeving some of the cables from my SeaSonic X650 PSU. :clap:Pictured above is the 24pin MoBo. Here are a few others!
Consider yourself a lucky man. You got your cables sleeved by the sleevemaster himself.:D Looks breathtaking!
This level of sleeving is making me want to redo mine :eek: Ridiculous. Mines good but its sure not that precise!
There is one thing I don't like about yout work Martin - It seems like nobody wants to show his system with your sleeves in :D:D:D
http://img13.abload.de/img/neverendings19i3rn.jpg
http://img13.abload.de/img/neverendings26o06u.jpg
beautiful, perfect color combination ;)
Nice sleevings!
Do anybody have any issues with sleeving the Fully Modular Seasonic X650 series?
EDIT: Just saw the amazing skills by Martin
Just go here and calculate: http://en.mdpc-x.com/ For every 10m of sleeve you will need about 1m of heatshrink. You will need the small heatshrink and sleeve for sleeving a PSU.
Does anyone know where I can find the following 2pin connectors:
http://i55.tinypic.com/313pphi.jpg
And then what type of pins would I need for those?
http://www.performance-pcs.com/catal...x&cPath=60_190
doesnt look like they've got a 1x2 though, so you'd probably have to use 2 x1xs
I know, right? What's up with that! :confused:
Oh well. Excellent work, though, Janik! :)
Michael: Thanks for posting! If you could post pictures of your rig with the cables installed that would be awesome :)
nnyymm: I had no issues with the X650's cables.
http://farm5.static.flickr.com/4104/...5511d306_b.jpg
