use awdflash ;)
use awdflash ;)
only the 333/800 strap helps ram use low voltage
i bet if you try those sticks on p35 they will need 2.34v@1200mhz
i think they would last about a year but ram is so cheap so .. lol
i lost so many sets @ 2.24V but that was on gigabut boards
dont go over 1.62v on nb its not needed
well that explains alot. im using 400/1066 strap. ill have to try 333/800 again.
yeh i dont want to kill these sticks so im trying again with new bios.
one strange thing i just noticed is when u save with cmos reloaded , it doesnt save ur fine delay settings. this sux becuase i wrote down my stable fine delay settings and saved with cmos reloaded.
but after reloading its didnt reload the stable fine delay settings? instead it kept the older unstable settings.
and u cant manually set it either , it has to be exact . i tried manually setting to similiar settings, but still no stability.
imo this is a problem becuase without stable fine delay u cant tweak ur ram at all.
I got it to 3.614 on 1.232 volts.
need help getting more out of it.
nb is 1.26
fsb vtt is 1.1
8GB G.SKILL F2-8800CL5D-4GBPI, vDIMM: 1.873 real, vNB 1.41, VTT 1.293, GTL Disabled:
http://img511.imageshack.us/img511/3656/32mhc3.jpg
Weakest sticks closest to the CPU. My weakest stick needs +0.04 more compared the second weakest. I have some findings I would like to share, sorry for jpg artifacts:
http://img528.imageshack.us/img528/7...weakingzk9.jpg
okay :) i'll try it
Have any one tryed the new beta bios 829? Any difference of fsb clock etc..?
new beta bios 8.29
LTQuote:
1. Fixed system can't display when built ATI HD 4870 X2 Cross Fire Edition.
2. Update Intel new 45nm CPU micro code.
http://us.dfi.com.tw/Upload/BIOS/X48AD829.zip
UT
http://www.dfi.com.tw/Upload/BIOS/X48CD829.zip
So i got it to boot and into windows @ 3.9ghz. i had to use 1.47 volts. i dont think this chip will do 4. :(
have been.
no, its not the newest. Im going to update it.
i cant seem to get it past what the cpu-z validation is at. i have pushed some high volts i.e 1.5 and it would boot at 3.9 but wasnt stable into windows.... its sad.
I have to ask this again. To go further I have to play with GTL ref but I dont have any success with it so far.
My settings for moment:
430x10
Vcore: 1.34V
PLL: 1.51V
VTT: 1.25
NB: 1.47V
This means my GTL should be 110, 105, 85, right?
Some one of you use lower or higher values so it is confusing.
If the system seems to be unstable shall I bump up all three or just the core who faild? I hope you understand what I mean. I have to learn.
I have seen many of you run my batch 4.5GHz+ but my goal are 450x10 for 24/7 use. My temps are great so I am not afraid of using more voltage! :)
Are you leaving GTLs default? If so, what bios are you using.
My only stable overclock so far is 3200MHZ on my C1 Q9450 (400FSB)
All default voltages with only GTL tweaks. I'm using the 602 bios still. Without manualy setting the GTL I'm not stable even at 3200 mhz no matter how much voltage I pump. I'm starting to think the 602 bios sucks for C1 steppings?
How the hell did you pull this off? I have same memory, Same MB, similar liquid cooling....I cant get past 400FSB... What stepping is your CPU and what bios please (is it the same E0?) ? I can't boot up with any overclock with GTL's disabled. I'm almost 100% sure that is what is holding me back is a bios that will adjust the GTL's closer to where they need to be. I'm tempted to go buy a new CPU. Everyoen swore up and down how good intel was and crazy overclocks and I can't get mine to clock for :banana::banana::banana::banana:. My highest STABLE overclock is using stock volts! WTF!
nice 8/29 bios have broken my mobo...i see on diagnostic display "10" and stop at 10 error code...nice very nice -________-
and not only for me other peaple have same issues...
10 code error: Auto detec EEPROM Check Flash type and copy flash
write/erase routines to 0F000h segments
