Damn went to 346 and windows locked up:slapass: So it begins! LOL. I need More voltage Scotty.Quote:
My Default vCore is almost what your's is at 3.6 Ghz. Stock for mine is 1.325. I have to run at 1.515 I think it is to be stable at 375 FSB.Quote:
Originally Posted by bobov
I was wondering is vMCH and vFSB kind of CPU dependant? I had to go to 1.65 vMCH to be stable at 365 FSB but at 375 I was getting random reboots. Takeing it down to 1.6v solved it. After I do a through run of Orthos overnight I'm going to try lowering it and vFSB some and seeing if I can't get it stable.
BTW. I'm using the newest version of Coretemp and I get same temps in Vista and XP doing a Orthos run. So I would say TAT is off in Vista. I haven't run TAT in Vista yet. I think Vista install is by far the easiest Windows install I've ever done to date. If it wasn't for the 8800 I wouldn't have had to install any drivers.
Their is an option in the BIOS I can't remember what the exact name is but it's like ASP or something. Like 2nd for the last tab on the right side. What is that for? I disabled it. Didn't seem to help with anything.
My E6600's Default VID is 1.225v. :)Quote:
Originally Posted by Maglin
Originally Posted by gtj
well c1e and watchdog are disabled
also eist is as well
im trying to set
1.4875 in bios
yes
1.4
1.675 or 1.7
8x438
mem
manual
default
tried both 533 and 800
5
5
5
18
2.2v
worked on my other one np ..even up to 450fsb
even 8x400 doesnt .. it really sucks cuz this system is beyond slow like this
try this...Quote:
Originally Posted by jetjaguar
increase vcore to 1.5500
drop vmch to 1.6
set 400 for FSB
force 266/667 for reference and memory frequency.
See what happens.
So here's what i got:
If that is all, shame on Intel...Quote:
Hello David,
Thank you for contacting Intel(R) Technical Support.
We, at Intel, appreciate your feedback on this matter. We will make sure your comment reaches the proper department for future consideration.
Thank you for taking the time to communicate this issue to us.
Important note: Should you need further assistance from us regarding your inquiry, we would highly appreciate if you could simply reply to this email of ours, instead of sending a brand new email, unless it is a different issue/inquiry. Thus, we will be avoiding duplicate incoming emails, and we will not lose track of the email thread.
Please do not hesitate to contact us again if you need further assistance.
Sincerely,
Daniel B.
They could at least have said that someones working on a fix for that, or tell me that they dont consider it a Bug since everyone should want to have C1E enabled and that i can go :banana::banana::banana::banana: myself.
Lets just wait for the next BIOS-release, IF there is going to be one :/
Edit: WTF did it id sanitize the F-word? Are the laws that strict in the US?
Originally Posted by cryptocat
:rolleyes:
It has nothing to do with laws, the people who run the site obviously don't want any bad language in the forums. Its offensive to some people.
More than C1E bug, I want unlocked downward mults!!!
I have to admit that this has been the MOST MOST MOST stable C2D board I've own to date... but not being able to use 9x or 8x to test my mem and PUSH the FSB has been annoying. I've tried crystalcpuid but can't get that to work properly (yes, i've said this 3 times now in this post and i will repeat myself as necessary until intel releases a bios that gives me downward mults)
so i've decided to try another board :)
thanks ill try it
but right now after messing around .. now i cant even get into the bios .. i tried everything .. the pc just turns on and the screen never comes on .. ive tried everything
I've got a weird issue with my Bad Axe 2 board.
Upon post, I get normal post screen, can get into bios, change everything I like.
It's just that I can't get the board to boot any more, gets stuck at "BA" or EB" in the lower left corner and never gets past that any more.
I also tried changing bios through recovery mode : doesn't work. Board stays with same bios as well :? Seems to do the recovery from floppy, after that nothing... same bios still... Nothing wrong with cmos battery either : tried changing it, no difference.
Any ideas anyone ?
Even with the jumper in config mode???Quote:
Well, BA is the search for removable boot media. Any USB storage devices attached? Something wrong with the CD/DVD?Quote:
Originally Posted by thorgal
What happens if you disable boot from USB, Optical and Removable in BIOS?
Thanks for your very quick reply :toast:Quote:
Just changed cpu, tried pci graphics, different memory... no boot...
I also removed my kvm switch, and about everything else as well, just 1 stick of memory now, cpu (E6700), PS2 keyboard and 1900XT : gets stuck at message "94" now (clearing keyboard buffer).
I'm just completely at a loss here at the moment ?? First time any bad axe gives up on me... The board just seems completely ok, just doesn't "move on" :(
PS : Jep, jumper in revocery mode : bios doesn't change...
It takes a while to do a bios recovery. If you have the .bio file on a diskette, insert it, remove the config jumper, and completely power cycle the box. It will boot at least 2 times on its own before the recovery is complete and eventually you'll see the messages about loading the firmware.Quote:
I can NOT use CL3 on my 2*1GB D9DQW set at any VDIMM (2,2-2,6V), at any VMCH (1,6-1,7V) on 1066 strap (266 ref.freq.)
is that normal (not)?
Originally Posted by heikis
Sounds normal to me unless its handpicked highly binned ram you really wouldnt see CL3 on just any DDR2 stick, if you want guaranteed drop $450 usd on Corsair 6400C3DF
I've got a stereo speaker configuration.
Firstly, I installed the sigmatel drivers but I had serious panning problems. I guess that the card was configured to something like 5.1 or 7.1.
I tried to select stereo speakers from with in control panel, but it didnt seem to affect/solve the panning problem.
So I installed the IAS version, set the card to stereo speaker (from within IAS) and voila, the panning problem disappeared.
Howerver, I hate IAS, in fact I hate all the applications that dont have an uninstall option.
Is there any other way to solve the panning problem and/or a way to properly uninstall IAS ?
I can do 500MHz 3-3-3-3 2,6V on 1333 strap (333 ref.freq.) :DQuote:
Originally Posted by ChaosMinionX
Now up to 366fsb:) cpu v @ 1.5v, mchv@ 1.6v, ddr2@ 1.84, memory set @ 333 / 667 running @ 733. IDCC temp reads at idle is 38*c / core temp reports 29*c.
At full cpu load from TAT temp is (tat=83*c)(idcc=78*c)(coretemp=69*c)
Tried 400 fsb @ 1.6vcore this morning no post:mad: Will try for 375fsb next.
Very pleased with the results so far as performance increase from old pentium2 400mhz are phenominal. :banana:
Just recived my BX2.
I have one problem so far:
My waterblock (Swiftech G4 Storm) won`t fit on this board cause of the blue mosfetsinks on top. :slapass:
Maybe I should try air-cooling instead…
Has anyone tested a Scythe Ninja on the BX2?
:eek:Quote:
Originally Posted by Bama Badaxe
Please can you take a pic? I´m going to put my Storm on my future XBX2.Quote:
Originally Posted by Nightprowler_77
The regular Storm works just fine, the G4 Storm is a bit different from the retail version.
Don´t even know they were different blocks :rolleyes:
So this is a regular retail Storm?:
http://img48.imageshack.us/img48/575...1746ep5.th.jpg
