And my cpu leaves me for the guy who just wrote above your post, you know, the one with a monkey in his avatar... :D
LOL....looks like this cpu's got a little competition then. I better get as many runs in as I can before I have to return the setup to NJKID32 :p:Quote:
Originally Posted by Tyrou
@ Gorillakos: Please ask NJKID for an extension for me so we can race :D
Originally Posted by s7e9h3n
Sure my friend..i will beg him..:p:
@Tyrou...it's a gorilla...not a monkey..:p:
My Effort.
http://www.motormice.com/_images/19secsuperpi.JPG
This is silent Air using an Si-120 and 1400 RPM 120 fan.
Ram is Gskill HZ 6400 4,5,4,12
Unmodded board.
Little something from the UK.
Boardy and Thickbrits T2600 on stock air with no mods at all!!
Enjoy, theres more to come!
Boardy
Well, I can confidently state that the Aopen motherboards are some of the biggest pieces of garbage I've ever used. The voltages on the board fluctuate like crazy, the overclocking is erratic, and there are still quite a few bugs that weren't worked out before production. It's just too bad that this gem of a cpu is stuck on such a POS mobo :mad: This particular Yonah DOES NOT appear to have a FSB limit.....
http://img349.imageshack.us/img349/6186/cpu39153jn.jpg
I think you're lying! :stick:Quote:
You better send it to me for comfirmation right away :toast: :D
Nice one you got there stephen.
The only place that thing is going is to Arizona:)
Hehe nice to see new results still coming :toast:
I gave up my yonah, I hate FSB wall. Conroes do 400 easily, no stress now :)
What does the "ES" stand for? Engineering Sample?
Indeed.
G
Is there any difference in an ES from a normal chip? Run the same? Worth buying an ES instead?Quote:
Originally Posted by Master_G
A little late but I've finally tried Intel for the first time. Thanks to Gautam and Denny
for the hardware. :)
Wasn't really sure what I was doing being an Intel noob so I just raised
voltages and fsb for this first time. (13x231 = 3005Mhz)
Ram timings are stock and a fresh install of
untweaked XP. Used the stock AOpen heatsink that came with the board. Hot
summer weather here didn't help, I think I could use a better heatsink.
Once I figure out how all this works I'll stick it under the mousepot... haha by
then everyone will be on Conroe ;).
http://www.jpop.com/gocchin/yonahfirst.png
LOL....ocing Intel cpu's isn't what I'd call "brain-surgery". There aren't the dozens of memory timings to figure out along with additional mobo settings, OS tweaks and other little nuances which give AMD clocking it's personality. Seems there's only really a couple of things to know with Intel.........Quote:
Originally Posted by gocchin
1. Your cpu will let you know right away whether or not it's a keeper. You can fiddle with settings all you want after you his a fsb wall, but that may gain you 1 or 2 FSB MAX.....
2. Cold cpu = fast cpu :p:
In all honesty, if the cpu wasn't able to put up some nice benchmarks, I'd be pulling my hair out either from frustration with this POS Aopen board or boredom from "point-and-click" overclocking :D
I hear you Stephen... when I first booted into the AOpen bios I was like... "that's it?? where are all the settings??" I think I do need better cooling. Gautam had this cpu up to 250mhz on air and 280 under DI... I was having trouble going above 235 but the cpu temps were at 50C in the bios... either a crap mount or I really just need a better cooler... :)Quote:
or it could be these Aopen SUPERBOARDS we're all blessed with :rolleyes: Welcome to the wonderful world of the YDG :toast:Quote:
I apologize for the misunderstanding, the CPU hits 250MHz FSB on air with a struggle (according to Mike), but with a lowered multi. I got it to 3.1 gigs or so. I never used the AOpen cooler. That was on a Tuniq tower with 1.5v. It didn't stay for long, I put it on DI on day two. It's very ironic. With AMD, you get a lowered HTT the colder you get, but with Intel, you get a way higher FSB once you lower temps.Quote:
OCing it isn't quite that simple. As I said, you should do the VCCA mod for best results. Otherwise it takes very gradual ramping of the FSB. When you hit one of those "walls" (I hit it at 261MHz on DI) running a 32M right before it helps. (Though more than nothing it passes the boredom)
Actually just noticed the part about your temps. That'd be the root of the problem. I was quite literally in the low 20's on air, even with 1.5v.
The board has given me many reasons to pull my hair out despite the nice benchies.
Well, I have to say the VCCA mod may not be for everyone ;) I did the mod to the board and tried up to 2.3V vcca only to find that the cpu actually would go HIGHER @ default vcca. With the mod on, I had troubles even clocking above 280fsb. After removing the mod, BENCHING @ 280+FSB was accomplished. Of course there's times which I'm bewildered why the system basically would randomly reboot itself @ speeds which I can do on air :wth:Quote:
Originally Posted by Gautam
Gautum no need to apologize my friend... I was only using your numbers as a point of reference and I for one know that nobody should expect to duplicate each others results even with identical hardware. Yeah I figured it's the temps for sure... there's no way I should be that high... I did put eletrical tape on the sides for a shim that may have been a tad high. I've got a tuniq tower on the way.. I'd like to fully test it on air before I head to DI.... and I'm sure with the right temps I should be able to go close to 3.1ghz :)Quote:
My Yonah (ES stepping 4) reported 50+ temps on air with stock heatsink as well... several remounts didn't change that by more than a couple of degrees... and with that, I was limited to 216fsb :D Really haven't had the time to mod the board and try DI yet...Quote:
Hi gocchin-san,Quote:
Just put it on DI for various testing after mod the board-- that's my suggestion;)
My step 8 Yonah was always stuck at 235.1MHz on air no matter what-- just a big frustration.
Seems getting a bit higher FSB each time under LN2:D
Cheers:toast:
fredyama
ES chips usually give you some play with the multiplier, in this case you can change it downwards.Quote:
Originally Posted by kaidomac
You are differences between chips just as with all CPUs, but usually they run like box chips.
G
Well it looks like I need way tighter ram... I made my goal of 250FSB on air... but
the elpida ram, while it clocks high isn't tight. If it was tighter I'm sure I could
have done sub 18.5s on air.
So if anyone has some good ram... ;)
Time: 18.812 (Super PI / mod1.5)
Clock: 3200MHz (FSB 250MHz x 13)
CPU: Yonah T2600 ES QHJJ Stepping 4: (2.16G/166x13/L2 2MB)
M/B: AOpen i975Xa-YDG mod (bios:1.03b)
CPU Cooling: Air w/ crappy Zalman AlCu 7000 24C ambient, cpu 30C in bios
Memory: F2-5400PHU2-2GBZX DDR 667 2x1024
VGA:ATI Radeon 700 (PCI)
HDD:WD Raptor 36gb
Power Supply: OCZ GameXtream 700w
Vcore: 1.63V, Vdimm: 2.1V
OS: Windows XP untweaked
MEM: Stock timings 4-4-4-12
http://www.jpop.com/gocchin/18812.png
The setup:
http://www.jpop.com/gocchin/yonahsetup.jpg
Very impressive, a lot higher than I bothered to try. Can't wait to see it on the mousepot. Btw, 250x13 is 3250, not 3200. ;)
You'd be surprised though, 2 gigs does perform real well clock for clock, even with looser timings. Tight timing 2 gig obviously is the ticket, if you can get your hands on it. You're performing exactly like a 1 gig set would at 4-3-2-4, a little bit better actually.
Hehehe...just imagine if Gocchin and I actually KNEW how to tweak Intel :p:Quote:
http://img57.imageshack.us/img57/9991/252x131m6hm.jpg
