Vitality and Lrrywild:
Drop your Multis to 10x and see if you can boot @ a higher FSB.
I just mounted the Zalman AlCu 7700 and had to fiddle with it for over 30 mins to get a good contact with and without the stock dothan shim off the heatsink. No shim now... still testing.
Set Vcore to 1.6 volts, CPUZ READS 1.520, VAGP to 1.8, VRAM to 1.5 (crap ram)
FSB 245, Multi to 12x = 2920 MHZ all on AIR!
Its not 3D stable yet , SPmod 1M crashes out, but better than my last full cold boot at 2820 MHZ. I think I can squeeze a higher windows SS soon.
RAM = 3-3-3-8-4 AAA , RAM DIVIDER @ 266 MHZ so real ram speed is 180 ish.
Will play with the system more tomorrow, install droop mod and see.
