clean look, u should have an y-line instead of t-line!
Edit: and are you running with or without nb block? ur picture shows both.
Here is watercooled setup:
- CPU: Alphacool NexXxoS XP
- NB: Alphacool NexXxoS NBX
- 2 X Alphacool NexXxoS Extreme 2 radiators
- Hydro Seltz L20 and Noise Isolator water container
http://koti.mbnet.fi/dani69/Muut/vesijaahy_valmis.JPG
http://koti.mbnet.fi/dani69/Muut/vesijaahy_valmis2.JPG
http://koti.mbnet.fi/dani69/Muut/NexXxos_blokit.JPG
Here's a pic of my old system:
http://www.4eweb.de/pc/tj07/40.jpg
I've got a couple:
- Silverstone TJ06 with stealth cover over optical bays and psu area, with extra fans
- E6600, DFI Infinity with a Thermalright HR-05
- DD TDX s939, with a 3mm alloy plate used to adapt to LGA775
- D4 pump, BIP 2 and a fillport
- and some other stuff
http://img227.imageshack.us/img227/5...achmentbc0.jpg
http://img300.imageshack.us/img300/6...achmentnk7.jpg
http://img208.imageshack.us/img208/3...achmentgw9.jpg
http://img300.imageshack.us/img300/5...achmentht2.jpg
http://img208.imageshack.us/img208/2...achmentsl9.jpg
No pictures with pretty lights for that one.
And slightly more elaborate:
- old yeong yang (old as in it had a Pentium 2 inside) case, cut up for a side window, 120mm fans, and repainted
- Abit AB9 with an E6300, etc - it's in my sig
- DD TDX, BI Stealth GTS 240, D5 pump and a fillport
http://img222.imageshack.us/img222/6...achmentik8.jpg
http://img222.imageshack.us/img222/3...achmentrx9.jpg
http://img222.imageshack.us/img222/4...achmentuq8.jpg
http://img222.imageshack.us/img222/8...achmentof1.jpg
http://img213.imageshack.us/img213/4...achmentwn5.jpg
http://img213.imageshack.us/img213/4...achmentfe8.jpg
hmm Camb on the first rig you had your rad supplying your pump, i think most would say its supposed to be the T-Line before pump inlet, easier to fill and prime...
other than that, its a very nice and clean install, nice use of 3mm plate there.
and the yeong yang simple also, only usual suspect of cube cases are the back side of mobo where the wires are located...
What has changed in your new system?Quote:
Originally Posted by krueml_
And how did you mount the rad in your tj07 case?
here is a pic of my setup:
http://s2.supload.com/thumbs/default...1116073333.jpg
I sold it.. :)Quote:
Originally Posted by Vandread
The rad is in the part below, behind the PSU.
http://www.4eweb.de/pc/tj07/42.jpg
There you can see it...
Shouldn't res be before pump? Looks like rad - cpu - res - gpu - pump - rad. Should be rad - cpu - gpu - res - pump - radQuote:
Originally Posted by hopper
It seems to me it is :)
Look closer
the bottom barb of the res makes a 180 degree turn to the inlet of the pump... this pump has the outtake on top ;)
Yeah, look where the tubing from the bottom barb of the Micro res goes...it seems to disappear but the only place it could possibly end is the pump. And if you look closely, it does. The D5 can be turned on its side and mounted that way pretty easily, so I'd assume the upward barb is the outlet.
Yeah, I see now. Probably was tired when I wrote the first post :PQuote:
Originally Posted by Garrett
The worklog: http://snipershide.us/index3.htm
Took me a month to get this all working proper, clicky link above for the full story. (no jokes bout water cooling kits or i hunt you down and kill yer kitten)
http://snipershide.us/images/sniper/...open_front.jpg
http://snipershide.us/images/sniper/...pen_back_2.jpg
http://snipershide.us/images/sniper/...de_close_1.jpg
http://snipershide.us/images/sniper/...e/cpu_done.jpg
big pic linky
http://snipershide.us/images/sniper/...complete_1.jpg
http://snipershide.us/images/sniper/...complete_2.jpg
hmm sorry man, not all of us have em kittens...
so no comments for now...
There's allways the animal shelter..... :P
kittens around here shoot back ;)
Hi m8´s :woot:
Here are some pics of my current rig, hope you guys enjoy it ;)
http://img.techpowerup.org/061119/EPSN0006.jpg
http://img.techpowerup.org/061119/EPSN0001.jpg
That´s right, it´s an Antec P160, but i painted it black and did some modifications.
[]´s m8´s
AWESOME job. love the look of the p160 in black.
Me to! Antec needs to smarten up. Most of us prefer black over silver!
Thanks you guys :D
I also really love the looks of it in black, its a beauty :banana:
Yup, Nice Job Foxy_PT
