double post on mobile phone. pls remove
Purple looks amazing! So many fittings!!! Has to be a new record surely? :p:
~Bex
Seriously though, how much $$ for the fittings? :)
It's how the internet runs. Tubes, a series of Tubes!
Hi guys. Nothing compared to the awesomeness that can be found in here but there ya go :)
http://img594.imageshack.us/img594/1777/04122010165.jpg
http://img651.imageshack.us/img651/782/04132010199y.jpg
http://img534.imageshack.us/img534/8344/04122010169.jpg
the fluid is tfc's..imo the purple kinda jive with the black fitting i guess, was thinking of going either purple or orange...
$$$ wise...hmmm dont have the faintest idea ... them tubes are Bitspower's sli/cf acrylic connectors actually, so almost no normal tubes here, so i guess practically 98% fittings....appreciate y'al comments,...wasnt too sure of posting here, blinded by the awesomeness of y'al rigs..
@Vlad'sAPE
Awesome! BP Madness O_____o
...btw do anyone know from where i can get (in europe) a LGA1366 Bracket for my Zalman ZM-WB5 block?
@Vlad'sAPE
Love it, Please oh please make a build log, or tell me you already have one ;)
heres my spaghetti factory:
http://www.digital-anarchy.com/image...a2426e08ff.jpg
http://www.digital-anarchy.com/image...4d05723238.jpg
koolance 720 rad/res/twin pump on top, black ice 80.2 rad on the back, koolance cpu block, koolance 8800GTX block, danger den 8800GTX block.
Vlad'sAPE that's an AWESOME build!
How is the flow with all the 90's?
the build is not quite finish :(....will take more updated pict soonest once its complete..actually latest, had to swap the sr1 with 2 x 120 tfc's as the sr1 was sucking hot air from the 2nd 59..as for the flow rate, i got 2 koolance flow meter, one for each loop, wasnt too sure on the reading accuracy though, so mainly use it for monitoring and system benchmark. i'd hooked up the meters to the zalman's fan controller and the meter convert the readin from rmp to mLpm...right now, the 1st loop (cpu + D5 + quad rad) is showing around 37++mLpm, and the 2nd loop (mobo + vgas + ddc3.25 + ddc3.25 + 360rad + 120rad + 120rad) is showing around 37++mLpm when one pump off, and around 46++mLpm when 2 pumps are on. havent quite finish bleeding, so the readings might change a bit later on...for the 2nd loop, i only turn both pumps on when benching, and only one pump during normal gaming session..i also have 4 temp sensor that hookep up with the zalman's, 1 for each loop, 1 for inner case ammbience and 1 for the outside case...thats why i'm putting the zalman's iin the case literally, so easy mnitoring through the case window...
I built my computer and water cooled it. I just ordered the new Intel 980X EE CPU and a new board.
http://i188.photobucket.com/albums/z...9/IMG_0203.jpg
http://i188.photobucket.com/albums/z...9/IMG_0205.jpg
http://i188.photobucket.com/albums/z...9/IMG_0209.jpg
http://i188.photobucket.com/albums/z...9/IMG_0210.jpg
EDIT: for the rest of the photos, see this thread
added a GTX 260 for physX :D, I´m thinking of watercooling it soon :D
http://data.fuskbugg.se/skalman01/-6...9626d15b2d.jpg
@Prava
Looks great man, what is the rear exhaust fan? I need something like that. Would you say the blades are bright white color or more grayish? I bought a Gelid Silent-12 (white blades) but not impressed with it's looks or build quality (plastic feels flimsy).
Vad, your plumbing rig looks awesome! With all those 90º and blocks, i was wondering how many pumps do you have :D Can we have more pics?
@prava can you give more pic. And tell the components of water cooling.:up:
EDIT: Nice photos, supercopa, but please remember the case gallery is for completed systems only, and not multiple shots posted at different times of the same build. You may want to post these most recent shots in the Parts Gallery - or perhaps start a worklog to show all your photos. Thanks, shazza
