any news on possible 2gb parts?
I will wait a little bit before jumping on the 5850 or 5870. It will definitely be a huge upgrade from a 3850 that I currently use.
^yeah using gtx295 i will also wait for time ..................
for ya have fun
No news on the x2? And it's past the 22nd so that date wasn't right. If I'd had know it would take this long would of bought a 5870 already.
Additional info about the Sapphire HD 5870 Vapor-X along with clock speeds and temperatures:
http://www.hardwarecanucks.com/news/...d-5870-vaporx/
does the Vapor X exhaust hot air out the back only or is it vented into the case too?
for the 5770 vMEM mod
can someone confirm that this:http://www.upi-semi.com/ProductFiles..._Datasheet.pdf
is the chip that regulates the vMEM???
And if it is,should someone solder PIN7 to ground?(after finding the correct vr of course)
FIXED LINK ABOVE...
@SONDA5 i got 17250 on 06 with the CCC clocks!
U reckon i should flash the asus bios??Didt get a lot from stock to 960/1400...:(
Maybe 1050/1500 will do bigger difference!
musashi doesnt fit unmodded on 5770...After some modding and cutting a heatpipe a little and almost destroying the cooler i managed to fit it on my 5770!
http://img21.imageshack.us/img21/456/dsc01868jq.jpg
http://img41.imageshack.us/img41/7416/dsc01869kx.jpg
http://img21.imageshack.us/img21/8115/dsc01870t.jpg
http://img25.imageshack.us/img25/1456/dsc01871hf.jpg
dropped 15 degrees from stock cooler @50%!
Thanks pal!I did 17 500 later on!!!:DJust open the card and put heatsinks on every spot i thought i should!Shame that 5770 does report memio temp...:down:
Now i am temted to flash the asus bios but i dont know...:cool::shrug:
Should i???Temps are 28 idle and 48-50ish load @1,2 volts!!!
And with one heatpipe down...
Catalyst 9.10 disappears in Windows 7
Ok guys, was all stoked because I got my new Sapphire 5870 and Windows 7 Ultimate.
3dmark06, Vantage, and Heaven installed fine as well as 9.10 initially.
Got great and smooth performance in all.
After a while though CCC 9.10 just disappeared!
I tried reinstalling CCC and would get a BSOD even in safe mode.
Now I can't run any 3d apps without a reinstall.
I suspect it might have to do with microsoft Visual C incompatibility with CCC 9.10 but not sure.
Anyone else have this problem?
Gonna have to do the painful reinstall otherwise...
__________________
Any firm news about release date, or previews about HD5970 yet?
Anyone think the 5870 X 2 will be worth the wait.
I have a 4850 512 overclocked with a s1 on air, I want to upgrade to something better on h20
Our foreign sources of AMD has informed us on the unofficial plan / date of the newest and most powerful graphics cards from AMD / ATi with kernel Hemlock XT. First in the world so we can inform you of the date of issue, which is a new ATI Radeon HD 5970 set at 16 November!
Source Link
Can't wait.;)
