hey bro, thanks for the help, i got my xp load screaming, i am lovin it, can't wait to build one for the r3e........ :yepp:
sweeeet :surf:
I joined btw :D
Commando is the best board for clocking Cedar Mills imho, but you'll still need mods for it, Vcore and Vdroop is easy but OVP is a bit tricky.
11th Yeah, great.
Fighting a great team :)
question, i am playing around with a e4400 that has a multi of 10
no matter what i do it will not go above 359 fsb, i tried almost every setting, also changing multi,
once it hits 359 fsb its not movin no matter what i throw at it....
any suggestions, i have tried most the bonehead stuff, but i never saw this before....
http://valid.canardpc.com/show_oc.php?id=1343913
Processor Number E4400
# of Cores 2
# of Threads 2
Clock Speed 2 GHz
L2 Cache 2 MB
Bus/Core Ratio 10
FSB Speed 800 MHz
FSB Parity No
Instruction Set 64-bit
Embedded Options Available No
Supplemental SKU No
Lithography 65 nm
Max TDP 65 W
VID Voltage Range 0.8500V-1.5V
That sounds like a very low FSB-wall...
Can you try that chip on another board?
Yeah, I'm pretty sure the CPU is to be blamed here... Nice work on the E6600 though! :up:
And thanks to some submissions by systemviper, SlaveOnDope and our new member quattro_, it's done:
http://a.imageshack.us/img713/7232/15k14082010.jpg
15k!!! :clap:
:party:
Congrats Gents! :clap:
Thanks! :)
SteveRo submitted his first scores today and brought the PCMark Vantage WR back to XS! :clap:
Well ran out of quad cores, so i put the UD3P on the shelf for a while.... (still got the Q9450 that i think can take 1st with dice or ln2 for later on)
So now i can focus on my REX, I have removed the regular heatpipes and put all Enzo copper on the chips plus a lot of fans,
I also did the socket prep for the SS last night.
So i figure a E8500 would be a good chip to put the REX thru the paces, not going for any records but i was
very interested to see if it had any 600+ FSB ballz.....
So the only stuff i have been doing with this board is building the HD loads, i have my Vista64 that i play in and i
built a very nice TinyXP for it toooo but anyway, I fired up the SS and was on my way....
So after a few boots and trying to get a better feel for the bios, also upgradign it to the latest....
I got it to easily go to..... Freq : 5278.95 MHz (621.05 * 8.5)
http://valid.canardpc.com/show_oc.php?id=1346257
So that made me real happy, so i played for a while trying setting, I think it can do much more then the 621. that was just to easy (knocks wood)
then i tried some speed runs and quickly hit Freq : 5537.89 MHz (582.94 * 9.5)
http://valid.canardpc.com/show_oc.php?id=1346305
So it was time to stop and i was very happy with this first test drive of the REX, i am very happy with it.
So now that i know the board got some chops it will be time to put some chips on it that i actually have a chance of getting close to the top
chips like the E8500 i don't think i can even get close without LN2.... but that is coming tooooooo!
well that was my Saturday overclocking adventure :surf: gooooooooo TEAM
Good to see you're on the REX now. :up:
Some guys even got the FSB up in to the 690s with the REX.
Here's an E8500 with REX at 693.99mhz: http://hwbot.org/community/submissio...eme_693.99_mhz
So maybe you can even push it some more. :yepp:
Keep clockin, great work!
Nice first run with the REX Steve! :up:
Which memory kit do you have, and what's your Vnb?
600MHz is easy with this board, I was able to hit 621MHz as well, but than it got harder, I'll have to look into it some more when I have more time. This board is great, I'm sure you'll love it! :)
Did you test your memory as well?
