I did raise my PCIE frequency ! I tried consistent and random values from 100 through 130 to no avail !! There must be something I'm doing wrong :confused:
IOH voltage raised too ?
Here my setting...I boot BCLK 225 very easy from bios but depent on your processor..can raise high BCLK or NOT :D:D
http://img193.imageshack.us/img193/3109/img0173z.jpg
http://img7.imageshack.us/img7/938/img0174avo.jpg
http://img199.imageshack.us/img199/2012/img0175l.jpg
http://img199.imageshack.us/img199/4222/img0177k.jpg
http://img140.imageshack.us/img140/2170/img0178m.jpg
Stable on SPI 32M and 3D 2006
http://img505.imageshack.us/img505/3316/225spi.jpg
http://img528.imageshack.us/img528/9522/2253d06.jpg
I am using Dominator GT memory and BIOS 1306. I have never had a cold boot issue (fingers crossed).
I have used various BIOS versions in the last three months. Is there any compelling reason to flash 1406? I am running at 3.64 stable with air cooling and I have been as high as 3.8.
Also, I have a CO stepped 920. Do you think I will see much of an improvement if I get a DO step chip?
I'm testing a 920 D0 with a ambiant temperature at 28 °
http://img339.imageshack.us/img339/6150/4400136v.jpg
Now I got big problems, first my water landed on the board! It's dry and running again! But now I'm not able to run the 21x200 stable with 2000Mhz Ram @ 9-9-9-24
WHY? @1024K I got an BSOD. Here are my settings:
VCORE: 1,2875
DIMM: 1,667
QPI: 1,40625
IOH: 1,2
ICH: 1,15
CPU and PCIe Spread Spectrum AUTO...should this be disabled? Should I reset my BIOS? It's 1406 from the owner before...It was not reseted by me for now!
Was the board powered up when it got wet? Was the water pure D I or did it have conductive aditives of any kind?
If it had power to it then there is no way to know what micro eloctromigration damage might have happened to a sensitive componnent. The base PCB itself would not be damaged but some of the microcircuitry may have been. Also, if the water was not totally pure and you have dried it but not cleaned it to take away any small but potentially harmfull residues you may still have some unknown high restance shorts bleeding signal to unwanted paths.
hello
I have a problem with for some time the computer starts.
if I start the computer cold (off for a few hours) I have this message at boot Reboot and select proper boot device, if turn off and restarts, no problem
if I hot start or restart, no problem either
I have the latest bios, 1406
that may come the problem?
thank you ;)
Anyone using the EK-FB RE2?
but under the rog logo near to chipset in present a fan??????
im in bubt about it....
i don't want a mobo with 50.000 hours capacitors, but with a little fan that makes noise and run for 1 year...
help me to discover....
its not a fan, its a light.
Im sure
Thanks Malik,
How was it to mount?
Was the supplied mounting kit good enough or did you need to use your own spacers, bolts or washers etc?
Also i got some HR-09's for the mosfets, i couldnt be bothered with the routing for both loops incorporating them too. Has anyone put these on their board?
i have 1403 installed but i saw that there is a 1406 in the ftp what are the differences between the 2?
Is it possible to flash the BIOS back from 1406 to 1403?
