I vote don't kill the ram, maybe just lower your clock to a safe level and deal with it...
man you guys have weird boards :rofl:
the big problem i think is gtl settings its like @ some voltage settings you need different % rate
with my 65nm i could goto 500fsb on auto but with my 45nm i cant use auto for 500fsb
higher the fsb i need lower gtl setting verry weird
got it. sadly, a c1 :(
im about to drop it in.
I'm still waiting for DFI to get 2 4870x2s working on this boards.. not to mention usb is unstable sometime with the 8/20 bios.
I have some BIOS from dfi.com.tw :D
DownloadCode:Dear Sir,
Update latest BIOS for X38/X48 series.
Major Reasons of Change:
Fixed system can't display when built ATI HD 4870 X2 CrossFire Edition.
LT X38-T2R --> X38AD827.ZIP
DK X38-T2R --> X38DD827.ZIP
DK X38-T2RB --> X38DD827.ZIP
UT X48-T2RS --> X48CD827.ZIP
UT X48-T3RS --> X48BD827.ZIP
LT X48-T2R --> X48AD827.ZIP
DK X48-T2R --> X48DD827.ZIP
DK X48-T2RSB Plus --> X48FD827.ZIP
LT X48-T3R --> X48GD827.ZIP
1: http://www.mediafire.com/?xh6uuuxhyya
or 2: http://www.fileflyer.com/view/ur7aeAn
GL&HF :up:
http://i306.photobucket.com/albums/n...R_4870X2CF.jpg
Thanks for sharing. :)
"X38AD827.zip" is missing. The file in the archive is named "utf-8__X38ADB28.zip" and that's an old beta BIOS.
You should remove the e-mail address to prevent spam.
i got my Q9550 to 3.6 @ 1.19v that good?
also, how do you flash the UT bios to LT
The UT and Lthe same except for the cooling...you can use the UT BIOS and flash it the same way you would flash the LT board...I prefer to use the Diamondflash method DFI offers. You could also use Winflash to do it in Windows if you want to do it that way. I have had no issues doing it either way.
I'm making some progress on these C1's
I now have 3200MHZ OC ALL default voltages with just GTL changes.
Vtt 1.100
NB default
Mem Default
CPU Auto (running 1.2v)
Id post GTL's but that is no help, instead I'm going to try to find a range or at least some percentages. Then I will go for 3.6ghz slowly. It might be better to just buy a new MB where I can leave the GTL's on auto and then I only have to worry about voltages, aparently the DFI MB does a terrible job of setting GTL's on auto. Maybe it's just this 602 bios that is terrible. Perhaps what works great for people with C0 steppings is not the best bios for C1's.....But now I'm afraid to flash it and lose all progress....
In what way do they change? I'm going for the % of Vtt. As long as I stick to a good working range of percentages I should be ok right? Or do you mean the percentages of vtt change as well? If that is the case I would be much better off buying a MB that likes C1 stepping CPUs. Or buying an older CPU for the DFI.
i myself have 4 775 boards so pickin the right one not hard
the dfi x38 is a fussy board
the higher fsb i go the lower gtl i need to set
mind you i dumped my x38 and took out my ut p35
if i were you i'd get a p5q series board if you dont find the right mix of gtl
Thanks I will try this later
edit: someone tried the bios and it didn't work
http://www.csd.dficlub.org/forum/sho...&postcount=240
I haven't tried it yet though.
This mobo is very nice, but I still prefer P35 :D:
http://img523.imageshack.us/img523/1723/nicerl3.jpg
BIOS 8/20, 1.218v real voltage, VTT = 1.293, NB not sure, 1.405v in BIOS, GTL 83 83 83. I'm running 8GB of the new G.SKILL PowerChip at 556Mhz 5-5-5-18 @ 1.899v confirmed with DMM so far, 4:5 divider and 445FSB, tRD 6. I have lot of tweaking left, have to be finished by tomorrow with the build. Anybody has any tips for "Memory Models" for this kind of memory configuration? Thanks.
im about to buy one of these second hand -Swiftech MCW30 chipset block.
anyone know if it fits the x48t2r ? and does the nb heatsink come off fairly easy for installation?
yah its all good i have one, u only have to cover the center 15-20mm^2
http://i35.tinypic.com/2ps2f03.jpg
and the push pins from teh stock sink come out easy
thanks , i just got it for $30aud not a bad price i think. now i can run two 4870x2 without that damn heatspreader and fan in the way. lol
Thanks ;), quick blend, vDIMM 1.899v (same voltages as before) G.SKILL rated DDR1100:
http://img206.imageshack.us/img206/6161/nice1zm8.jpg
I know it only few minutes, I will post BIOS shots tomorrow, it takes huge amount of patience to figure out right DS, DSS, Skew, Delays and other settings :). FYI, this is on 8/20 BIOS.
has anyone successfully flashed 820 with winflash? ive tried everything to flash with winflash . doesnt want to work. tried exe and ziped files. both dont work.
whats the trick?
dont want to use floppy . dont have one nor want one.
