Originally Posted by gtj
Thank you..also should I leave it on Auto or set it at EXT PEG?
Leave it auto. Unless you also have a regular PCI video card, this option doesn't do anything.Quote:
Originally Posted by sdgserv
Thanks Blacklash! I have disabled C1E but left watchdog on. Still no luck with OC'ing. I can run stock no problems, then I OC to 3GHz, no problems. Then maybe 3 reboots later or even 1 reboot later I get OC failed. Like the BIOS loses settings or doesen't save them properly. Could this be the watchdog feature playing funny buggers? I'd like to leave it on if possible because without it, recovering from a failed oc is a NIGHTMARE. I have to remove the CMOS battery.Quote:
Originally Posted by Blacklash
The watchdog is severely broken. You're going to have to disable it to get anything serious out of the board. Yeah it's a pain to keep moving the jumper but it's the only way. If you have a 3-pin fan extension cable you can plug it into the header and use the jumper on the end of the cable. Or you could wire up a switch.Quote:
Originally Posted by J@mmer
EDIT: You shouldn't have to remove the battery. Just move the config jumper and power cycle.
Roger that..:)
I have Bios 2634, and I disabled C1E in the bios. If this didn't really disable it, what does that mean in terms of overclocking or other performance? And if I really need it disabled, how do I - short of installing a different bios?Quote:
You can turn it off from Windows with RMClock or Everest. It's only a pain when you're tuning/benchmarking and even then, it's minor. Long term, it's a good thing since it will keep your temps down when the cpu is idle.Quote:
Originally Posted by Salamander 2
So, should I go back into the bios and enable it - just in case Intel fixes this with a later bios?
Also, I downloaded the TAT and turned it on while using Orthos. The temps for both cores varied in the 50 degrees, occasionally ramping up to 58 and 59. When I turned off Orthos and then started the workload analysis tool in TAT, the temps jumped into the low 60s. Is the workload analysis a better stress test than Orthos? What is the maximum temps at which point I should back off a bit on the overclocking?
Ahh roger that. I was hoping you wouldn't say that but I'll give it a shot tonight. Cheers GTJ and BLacklash, you guys are invaluable on this thread. :clap:Quote:
i got everything going in the bios. set it to RAID
then rebooted... hit CTL - I and setup a raid volume.
everything looked correct in the bios after that.
now i have 2x36 raptos that show up as 72gig
and 1 320gig drive
i popped in the Vista x86 cd. booted up. plugged in my code.
then it says "where do you want to install vista"
i have 2 options:
0 unallocated space 68gig
1 unallocated space 320gig
i picked the 68 & hit "new" for partition. created with the entire size.
then i get "this computer's hardware may not support booting to this disc"
hit "next"
"windows is unable to find a system volume that meets its criteria"
ugh. suggestions? i tried loading to my 320gig storage with no luck as well.
F6 method is not necessary, right? nor is loading any raid drivers at this stage?
hmmm.
Nah don't worry about C1E right now.Quote:
Tat definitely does stress the cores more than orthos but doesn't test your memory at all so orthos is a better all around stress tester.
Your temps are not bad at all. If you start seeing anything higher than the mid 60's under an orthos test, I'd back off a little.
Anything above 70 is getting dangerous. 85 is pretty much fatal.
No drivers required.Quote:
Originally Posted by argylesocks
First, double check that the array is the first boot drive in BIOS. If it isn't make it the first one and try again. If that doesn't work...
Boot the CD again but press "repair".
Open a command window.
type...
diskpart
select disk 0
clean
create partition primary
select partition 1
active
format fs=ntfs quick
assign
exit
Now reboot and try again.
yes, the array was the first.Quote:
i just deleted the array, then recreated it... (same info)
then loaded windows again... this time, i didnt hit "advanced" and didnt create a partition... i just hit "next" now its copying files.. hmm
ill keep ya posted. thanks :)
ps: my cpu temps in the bios are at 30C thats normal, right? i was worried i messed up installing the cpu/zalman
edit: dunno what i did different.. but vista is installed :)
Glad it going now.Quote:
30's is good.
I agree with you that over 70c is bad, but doubt 85c is fatal.... I mean, 85c is the Tjunction temp, your core throttle down at that point or your cpu freeze. I got mine at 85c while doing some benching and it just froze. I would defenitly not run that for more then small benching sessions but i was wondering if you can actually kill your chip with 85c.... The reason why i have doubts is that QX6700 are actually 2 E6700 stuck together and their tjunction temp are 100c and while running them at stock speed with stock cooler 85c load is "normal"...Quote:
Oh btw anyone here plannig to do crossfire with some R600s on this board?
Not fatal for you, or I under controlled circumstances, but for those less experienced "pretty much fatal" is probably true. :)Quote:
Originally Posted by shogo_ca
BTW the default state for the thermal protection is "disabled". Check Everest or RmClock and you'll see it disabled.
Well, we'll see if they are ever released :rolleyes: , and if they are gonna need 2 x16 slots...
You need to set all settings to default, changing only the watchdog/c1e settings and successfully boot before you try to change anything else. After successfully booting at default settings you can reboot and start tuning :cool:Quote:
Originally Posted by jetjaguar
:)Quote:
so how long before i can start OC'ing??
should i let things 'settle in' for a few days...
this sucks .. i guess ill try to overclock later .. im sitting here at stock 2.13ghz .. its so beyond slow .. vista is like crawling .. i cant believe this crap .. hopefully i can get this board overclocking or im gonna have to go back to the 680i
Recap please. Exactly what settings are you trying.Quote:
I have just started tweaking after loading XP & 71 critical updates.:)
With cpu @ 333 x 9 and TAT running 90% workload in the background coretemp is showing 55*C & TAT reads consistantly 12 degrees higher @ 68-69*c. VID is set @ 1.325v. Idle temps are 29*c:banana:
Hehehe it's as soon as you go over 334FSB is when the problems start. ;)
I have tried bios 2333/2507/2634, all bios can run 400MHz X 9 without any problem, as long as you disable watchdog in maintennance mode.
Mobo: D975XBX2 Rev. 503
CPU: E6600
vFSB: 400MHz
vMCH: 1.50v
vFSB: 1.20v
vCore: 1.3625v
Mem ref: 266MHz
Mem runs @ 1:1 400MHz 3-4-3-8 2.2v
Hope it helps. :)
