do you have powered USB hub attached. I do. maybe that's the problem....Quote:
What bios version is best? want to oc
Didn't matter what I had plugged in....whether I used 0 ports or 6 (three being hubbed). Just randomly started working :confused:Quote:
Originally Posted by ingenue007
Completely borked my OS now with the sound card settings....set AC97 for front panel and I can't get my X-Fi to not crash windows any longer, lol.
I think you need to register to RMA no ?Quote:
Originally Posted by Kakulukia
And vice versa is a common latin phrase... so if you natively speak a romance language you should be a little embarrassed for asking.
It means the other way around. So if I were to say, apples are not oranges, the statement oranges are not apples would be true. I can shorten this by saying apples are not oranges and vice versa.
It can be abbreviated 'v.s.'... so apples are not oranges and vs.
Hi, I've read the notes in first page, but still I've some questions:
1) The mobo suffer of cold boot strating the system or rebooting it? Like P5B Vanilla (and maybe P5WDH) do...
2) What's the average limit of the FSB with a stock mobo?
Thanks.
the unknown device in device manager is an asus chip used to read the temps.. drivers for this dive are installed with probe or ai booster... so install 1 of this 2 to get rid of the problem..
Any new BIOS?I've moved from p5wdh to p5b dlx,but the support sucks..
I`m going from P5W to P5B E+, what i like to know is if it is possible to port my Raid 0 from ICH7 to ICH8 ?
Anyone done this already ?
Originally Posted by ic3m4n2005
yes without any problems
You don't actually have to install any of these packages if you don't want to. All you need is to extract the Asus ACPI drivers from the archives and point your device manager in the right direction.Quote:
Originally Posted by ninjaskija
Hi, does someone know how i can set settings like these:
http://members.cox.net/zemzelettmail/stable.jpg
In Asus probe. In Asus probe i only get vcore and some temps.
But that guy has very very more.. how do i do that?
buy a new asus striker extreme :p:Quote:
Originally Posted by barzi
Ah it's like that :D
He meant; the P5b-D doesnt have all those tempsensors as the xtremestriker.Quote:
Confirmed!!!!!Quote:
Those, who have an uknown device in hardware panel, just install probe or Ai booster ( i have only tested probe) .
@Kakulukia
yeah thats right
Just posting because i got a new P5B-D wifi from an rma and the cold restart thing doesn't happen anymore. I guess it is a motherboard problem as the setup was identical on both boards.
can some one please answer this question.
In bios on all 3 of my P5B deluxe boards that i have tried in bios when you go up or down with settings it is like slow(slide show effect) and refreshs page slow, only started happening.
What is the cause of this. could it be that i have bad ram or something?
hey.. i wanted to ask.. what is the current best P5B Deluxe overclocking bios..
im using GSKILL PK pc6400.
Originally Posted by markymoo
I added another sata drive to my system that I already had up and running with Raid0 without any issues.
Ok i have fiound the problem when 8800GTX is installed on my P5B the bios goes crazy and is very slow it is like using bios with slow motion..Quote:
Originally Posted by X.T.R.E.M.E_ICE
My question is does any one know how to fix this??
did you try the 0903 Beta Bios from Asus? (only for P5B Dlx!)
http://amd.co.at/anti/asus/P5b-delux...s/P5BD0903.zip
Edit: the 0903 fixed some problems with 8800GTX Cards, but i dont know which problems.
That's weird...Quote:
Someone else pls confirm this.
when i remove the 8800GTX and use a 6500 PCI_E i don't have the problem. i am using bios 0804 will try the 903 beta right now.Quote:
Originally Posted by JoeBar
Same problem here currently using 0903 bios.Quote:
Here is a video of the problem. 903 bios.
http://www.youtube.com/watch?v=pBI_kB0g9eM
