This is a nice report, thanks a lot! :DQuote:
Originally Posted by andlcs
(I write all the perfect reports on my .txt and after ~5 I update the list).
I know as I have written few posts ago ("directely from Mushkin"), I will correct soon. ;)Quote:
Originally Posted by Eloxxd
You must remove the metal clips. To do so, put a screwdriver or something underneath it. When done removing the clips, gently pull the heatspreaders off. Between the heatspreaders and the chips there's thermal tape.Quote:
Originally Posted by calcal
thanks comp freak, the first part worked but the second part didnt. I cant pull the heat spreaders off, its too tight :(Quote:
Originally Posted by Comp-Freak
It's a start ;) You must lift the heatspreaders on the same side the contacs for the ram slot are. On the other side, the 2 spreaders are hooked into each other.Quote:
Just wanted to post that i bought a pair of Patriot 2x512 pc3200XBLK and i recieved them today. they have the BP 815U pcb (Thats RED pcb :) ) and the tccd 522 chips. i havent run them yet but suspect they will fair just fine...
peace perc,
Yeah, they will man! Report us your progress! :DQuote:
Originally Posted by Perc
so far these new patriot tccd 522 are acting more like my 256 tccd sticks then my older crosair 4400 512 tccd sticks... these 512's here will let me run 270/280htt at 2.7v and 2.5-3-3-8 instead of the 2.5-4-4-8@ 2.8v i had to use with my 4400 crosair tccd 440 memorys. im going to see if they run 300htt or not at these timmings? im sure they do but you never know...
peace perc,
I think PQI evolved out of what used to be PMI, didn't they?Quote:
Not bad man! Also the clock of your Dual Core is awesome! Let's see if your memory can do more! :DQuote:
over a year ago pqi bought pmi, so basically yes.Quote:
Originally Posted by serlv
lol yeah i cant complain about this dual core so far with these patriot 512 sticks im at 280htt 2.7v 2.5-3-3- 1:1 ofcourse... with my other crosair 4400 tccd i was running this core at 300htt just havent tried these new memory at 300 yet im sure they will do it np. heres a screen shot of 300htt using my crosair tccd...Quote:
Originally Posted by Punisher!
*edit* heres a screen shot of the new patriot doing 300htt 2.5-3-3-X using only 2.7v. compare these to my crosair at 300htt where i had to use 2.5-4-4-X using 2.8v id say these new patriots deff oc nice with even tighter timmings then my old tccd 440 crosair...
peace perc,
Hello
Somebody know what chips have OCZ EL PC2700 rev. 3.2 256MB sticks ??
SPD timings 5-2-2-2
Regards
Peter
:banana:Quote:
What about some benchies? :p: :toast:
i can post a few i supose. i just never see anything special about my mem scores so i never post them...
peace perc,
Just got my OCZ4001024WV3DC-K BH-5 goodness new stick's i think ill break them in right with some high fsb lovin :)
hi!
i've got a question:
i'm trying to to buy old bh-5/6 and i got a message where it was written that geil ultra pc3500 p/n MAG16UL6464D2TG4A-KT is winbond. but i dont have any info about the chips.
what do you guys think, could this be winbond bh?
ps if anybody sells 2x512 winbond bh5/6 pm or e-mail me please.
Black PCB no. Green PCB ,maybe.Quote:
Originally Posted by i found nemo
oh, on another post here on xs it said that it had utt chips :(
Look this:Quote:
http://forums.mushkin.com/phpbb2/viewtopic.php?t=2057
Maybe the HP3200 with green PCB on ebay is. Not confirmed yet.
I would say buy the Redline.
know a place i could buy a stick of 512 for 60 bux?
Are your XBLK timings with command rate 1T or 2T?Quote:
In general, do you guys think (keeping everything else the same) that 1T give 1%, 2%, 5%, or more, improvement in sustained memory bandwidth with a X2 3800 type cores.
And lastly some say that X2 3800 Toledo OC better than Manchester. But some say, because Manchester smaller die uses less power, it should OC as well or better. Which is correct?
Big update | 29/09/2005:
Updates\Corrections:
1GB XP3200 Dual Pack 2-2-2 (2x512MB) tccd/tcc5
1GB XP4400 Dual Pack 2.5-4-4 (2x512MB) tccd
1GB REDLINE 3200/3500/4000 (2x512mb) UTT/ch
PQI TURBO DDR550 is using Hynix D5 + Brainpower 815
OCZ VX PC3500
CORSAIR ALL Rev. 1.X
1GB Sticks List coming... any help is appreciated (not just words... you know I need facts to realize a reliable list)...
Bye! :D
Iwould like to know which core to gofor also..
I was thinkinmanchester but now I dunno
I have 2X1024 pdp 1024vv 3200 that has done 254 2.5-3-2-5 and 2.5-3-2-0-7-16 :)
Waiting onmy new mobo to try them out more
Im getting the ubber Asrock and will report results as soon as i can sell the dfi nf3 and afford the components, i might throw em inthe infinity and see what theyll dowith 2.5-3-3 or 4-3
Update:
Corsair XMS-PC3200C2 Rev4.3 (2-3-3-6-1T) --chip--> Samsung TCCD & TCC5 (Rev. F) ~ Brainpower PCB
Ok! Yeah, my mistake, OCZ corrected and the others signed on my .txt :D.Quote:
Originally Posted by babyelf
Thanks man! ;)
np ;)
I have not seen the new G.Skill Extreme Series DDR 500 PC 4000 on here yet. 2 @ 1GB Samsung UCCC 3-4-8-4. I just purchased and got them on Friday.. still trying to find out which bios works best for the DFI NF4 Ultra D board. The 623-3 bios works but I cannot figure out how to get above 250 FSB on it with those timings. Now the 704-2BTA bios I can am Prime95 stable as high as 280 FSB. Timings are the same in both, 1/01 E-3-4-8-4 with everything else set at whatever the bios defaults are. On the 704 bios I cannot seem to get it to run on a divider at all.. most likely something I am doing wrong. I am not saavy messing with memory unfortunately.. way too much to try and absorb and too much going on.
OCZ DIMM 1 GB DDR-400 (OCZ4001024ELPE, Platinum EL) with infineon Ram :(
Hi guys,
Did you see that - Mushkin xp 4400 512 MB for a very reasonable price :) click
Someone familiar with the chips of that memory modules. According to mushkin they no longer use TCCD chips. I wonder if these modules are with TCC5 or....
tcc5 last I checked.Quote:
Originally Posted by Billy_BAD_Boy
Incorrect: Most are listed as TCCX, which means Samsung didn't classify them.Quote:
Incorrect as well. Multiple ICs from different manufacturers can be under the same version # (x.y).Quote:
Originally Posted by Micutzu
NEW Corsair IC Inquiry Thread
fyi, there's no such thing as unclassified samsung ic's.Quote:
Originally Posted by Wired-HoH
even ramguy doesn't say that:
TCCX = Is a down binned TCCD IC weather from Samsung or by us, so it can be a TCC3 or TCC4 or TCC5 or a TCCD marked on the IC, but it really does not matter what IC we use as long as the modules meet their tested spec.
Bah, was thinking Corsair, typed Samsung :0
In don't mind if Corsair didn't classify them. Their performance are assimilable to Samsung TCCD & TCC5, so it doesn't matter if it is written TCCX.Quote:
Ultra XL PC3200 Samsung TCCD 510 BP6U815
http://www.tigerdirect.com/applicati...071046&CatId=0
The other dude with samsung tccd sticky must be sleeping :D He hasn't add this one yet. So I'll post it here for you Punisher. :toast:
They are moderate overclockers...
Common guys....no one tried this extremely cheap memory (only $58 for a 512 MB stick). Keep in mind that the dual pack cost about $170.....what is indeed the difference?Quote:
Anyone know something about this
2x512 Corsair XMS3200C2PRO v4.3
XMS3202 V4.3
0518032-3
chipset... max fsb, timings etc.
thanks
ramguy at corsair support forums has reported c2 v4.3 multiple times as either samsung tccd/5 or promos.
you may post details there and wait for ramguys reply.
alternatively, you could try and see if your ram can do 2-2-2@200 using low vdimm. if it does, its should be samsung.
yes it does with 2.8
now i have 240 @ 2.5-3-3-8 can i lower timings anymore? cause i tried and it freezes.
is system faster with FSB default 200 (CPU @2Ghz)with 2-2-2-2-5 or FSB240 (CPU @2.4Ghz) with 2.5.-3-3-8
that looks like samsung tccd/5. those are typical timings for most tccd/5 @240. however, i believe you should be able to push your ram further, upto 260-270, maybe even more.
as for 200vs240, real time performance differences should be minimal, with slight advantage for higher frequency.
They are on the list... Pro means just "with LED" :D.Quote:
Originally Posted by Sparxxxy
ok, thanks...
Are ALL new GEIL pc3200 value blue UTT-BH5?
Yeah, all new ones... but the risk is always present seeing that you still could find old ones.Quote:
Originally Posted by ZeroX
sorry my poor english, but i am a french man :)
i have recover my ram to the sav of corsair
CORSAIR XMS 4000 V3.3 (3-4-4-8)
but i don't found what chip is in this ram
if you can help me, thanks
xms4000 v3.x are samsung based most likely.
go to corsair support forums and post info about your ram (including lot#) in ic inquiry thread. you should get the most accurate answer there.
Well, the 2x1GB cannot.Quote:
http://www.newegg.com/Product/Produc...82E16820144322
True, in fact mine is called 256/512MB STICKS RAM LISTING ;).Quote:
Originally Posted by Martin Cracauer
Any idea what oc. we could expect from this combination?Quote:
It's a pitty that in the forum has so little info about the GEIL Value blue :(
OCZ EL PC 4200 (2,5-4-4-7).
Anybody know what chips are in these sticks?
Anyone any idea when the '1gb sticks ram listing' is going to be updated?
Exams period here... :D.Quote:
Originally Posted by [MsT3r]$eR9!o
is still avaible in some shops this ram Mushkin PC3200 Level II V2 (2-2-2) --chip--> Samsung TCCD?? how it is ?? is it like others tccd rams or is it worse??
thank you very much
one to add is some mushkin HP3200 2-3-3 (P/N:991432) 512 module ships with
0450VR
V58c2256804SAT5B
which according to here(http://tech.vault9.net/forums/Memory...st-t22118.html) is:
Vitelic 5ns - This is 5ns ram from Mosel. It is commonly found in PC3200 offerings, and at this speed is rated at cas2-3-3-6. This is not bad, but nothing out of the ordinary. It is similar to CH-5 from Winbond. This ram can clock to around 240 MHz and hold decent timings such as cas2.5-3-3-6. If timings are kept at 2-3-2-X, then this ram will typically max out around 220 MHz. This can be found in Corsair XMS3200, Geil Ultra PC3200 and PC3500, OCZ PC3200 and PC3700. This is not a bad choice of ram at all. It offers great overclockability while still holding very respectable timings. Although Mosel is not a well known name in the memory industry, you can see that the top memory manufacturers are using their ram. If you can get these on the used market, they would make a very sweet deal. I have not seen these in Value Ram offerings, but that does not mean they do not exist. Identifying these can be somewhat difficult, as many companies re-label them. Take a look at the ram list to be sure of what modules contain these chips. You can identify these chips by the last 5 characters being SAT5B.
i got this from a RMA of some blue Cl2 stuff....UTT...dammit, i feel robbed..owell..
Hello
i got PC3700 (2,5-4-3) --chip--> Samsung TCCD (rev. F)
no TCCD chips.
Mosel Vitelic 5ns and BrainPower PCB 808
if just find them with a color heatspreader, but these are silver.
As stated by someone else above, the 2Gb kit is not UTT/BH-5 as they do not like high voltage and do not OC above 216 (my max so far).Quote:
Mine have a PCB marked Elixir which I take to mean that they are made by Nanya and presumably the chips are also Elixir 5ns. PS - those Blue heatspreaders are stuck on so cannot remove them to see the actual chips.
With relaxed timings (as per my sig) they are stable with OC on a 166 divider.
