-----------------------------------------------------------------Quote:
Originally Posted by snatchmonkey
same thing happen to me. I was playing counterstrike friday night, switch off computer to go to sleep.
first thing on sat, switch on my computer. NOTHING. the power supply refuse to power up, only LED light ON on the YDG motherboard.
my power supply problem?
reset my CMOS. (PS off) take out all SATA cable, take out graphic card, nothing happen.
Got a new power supply, nothing HAPPEN.
finally take motherboard out of casing and connect minimum parts, NOTHING HAPPEN.
finally attempt CMOS reset with power supply ON. Everything works again.
NOthing is damaged. I have to buy a new ps for nothing.
Recently i performed BIOS upgrade to 1.8, but work well for a few days.
Also i found that my aopen YDG do not like my razer copperhead mouse, it can prevent BIOS from booting. (1.3 BIOS OK, 1.4 above NOK)
I solved the problem by using a PCI USB card.
I also found that it did not like my G15 keyboard. (1.3 OK 1.8 NOK)
But i found that in BIOS, remove USB keyboard support.
if you cannot boot after upgrading bios, take out usb mouse, usb keyboard, put in PS2 keyboard and try to enter BIOS. set default value. boot if OK, put back usb keyboard.
Well, this is motherboard have strange bugs here and there, but all in all, i love it.
I only can go up to 260 FSB on T2400. Which I hope can go better.
