You have disabled the IDE Raid Controller in bios ??Quote:
Originally Posted by Joe Camel
If yes...just enable it back....and your Nvidia will work just fine.
thx man.Quote:
Originally Posted by stummerwinter
Anyone have problem with old pci video card ? I've tested 2 mobo ,2 Yonah and 2 kits of memory and no way no post :/
No problem so far with PCI ati 2MB. Tried both PCI slots?
Must be THAT video card.Quote:
Originally Posted by 200%absolut
I run an 8mb ATI Rage fine on mine.
gawd dammit.....I just spend all evening riggin up a Lightspeed unit, just to find the same 224FSB bug descibed here. eeesh.
Polarfar
Should have tried on air/low multi first :).Quote:
Originally Posted by Polarfar
I did.....the board went to 224 on an old 478 Celeron stock cooler, so I figured if I froze the damn thing......Quote:
Originally Posted by R101
Well never mind. I have sent a mail to an Aopen engineer in Holland. Maybe he can tell us whats going on.
Hey guys , what memory this board works with for sure ? Just got my OCZ PC2-8000 Platinum XTC 2x1Gb kit today (Model: OCZ2P10002GK) from newegg and it won't even POST with that damn board !!!! :mad: $500 wasted for nothing :nono: :mad: I am going to try another kit , plz help AMD guy choise the right one that works with that board for sure . Interested in 1Gb (2x512Mb) and 2Gb Kits (2x1Gb) and maybe somebody knows some cheap value RAM too so i can just try and make sure it's mem. incompatibility issue or not ? :confused:
Thank you :)
mine will boot with this stuff:
http://www.newegg.com/Product/Produc...82E16820144326
think G H Z had a problem with his Mushkin booting in this mobo....huh :confused:
PS this stuff boots too (D9) ;)
http://img186.imageshack.us/img186/4...04850gc.th.jpg
Thanks for the link :toast: , may be i'l try that Ballistix kit , seems a bit pricey for just 1 gig but i gues it's worth it if it's D9 Fatbody :woot:Quote:
And about that Mushkin 881465 G H Z has problem with ... seems like that Aopen board needs some major BIOS update or some :slapass: lol
corsair value works in mineQuote:
Originally Posted by Gorod
and muskin - blue heat speadors also
ibbyok thanks , i'l try that if i dont find money to buy Ballistix :) Is that 533 or 667 ? they cost the same at newegg :) Are they ok to o/c ? :DQuote:
this kingston working fine by me 2GB DDR2-900@ 400MHZ@3-4-4-8 :clap:
http://www.newegg.com/Product/Produc...82E16820134017
The board needs Vcore and Vdimm mods to up Vs from 1.5/2.15Vs.
For cold boot Tcoremod will help....http://www.xtremesystems.org/forums/...t=95411&page=2
Anand has a review up and seems to have some oc jumper stuff in it:
http://www.anandtech.com/mb/showdoc.aspx?i=2750&p=4
Maybe I´m to stupid, but I can´t get clockgen running...:(
I don´t know which pll to choose or set it the right way.
Always no posibility to change something...:(
Use 1.0.4.4 version and the last PLL from the list, don't remember name
Thanx, works perfekt...:toast:
Tried this 9541XX recommended for 975...:rolleyes:
So it seems to me that all these mobile chips, whether Yonah or Merom, have an FSB wall that no cooling will get past (unless you hit the lotto like Tyrou). So is it the chips or the board (e.g., chipset)? And why would one want to drop $300 on this board under these circumstances?
Is there some reasonable expectation (i.e., evidence) that this FSB issue will go away with some future CPU stepping or bios revision?
I love the idea of these low-wattage (lower than Conroe) chips under extreme cooling, but I also love the idea of cold fusion. :lol:
Extreme cooling and voltage mods will help with the FSB. But those things are not going to turn a so-so CPU into a great one. There are various theories about the FSB. Some say it's the board, while others think it's the CPU. I think most people who've actually used Yonah have concluded the CPU is more likely the culprit. At least that's my conclusion. I have two different Yonah chips. Same board, same BIOS, same RAM, same settings. One CPU overclocks much better than the other.
So those getting 225 FSB on air are getting considerably higher higher on phase?
Originally Posted by sierra_bound
Single-stage will usually give you an extra 10-15MHz on the FSB. I say "usually" because some people can't get past 235, regardless of cooling.
is T-core mod a *MUST* for SS temps?
And if you knew how annoying it is, even worse that fighting AMD coldbug :p:Quote:
