http://i19.photobucket.com/albums/b1...evin/Res-1.jpg
Looking gorgeous.
Try to get some black screws, maybe? mcmaster has lots of black-oxide screws, search for "Socket Cap Screws"
...sweet...
sdkevin what Lian Li case is that
Lian Li V2100B, you can check out my thread called "first time etching window for V2100" and you will see why this is a bit different from other V2100
Man why don't people like my SS screws? I think they give it that nice touch... but if you must have black it is part # 97763A142 at www.mcmaster.com
I like those screws, only use black oxide if you have Clear bay mount. Only downside is acrylic bay mount, I have to work extra careful so I don't break it :)
woohooo
just got the motherload.....................
looks really nice!
once I get around to mounting it (this weekend perhaps) pics will be posted
are those Innovatek LED plug are G1/4"? hope you have some LED plug w/ LED included in the Res for Special Request ONLY so I don't have to find it :) can't see my water flow anymore!
http://i19.photobucket.com/albums/b161/sdkevin/Res3.jpg
Huh? Me include led plug? You can buy one here: http://www.frozencpu.com/ex-res-42.html?id=k9msE3NE and if you want a water temp gauge: http://www.frozencpu.com/ex-res-52.html?id=k9msE3NEQuote:
Originally Posted by sdkevin
so your res. matches Innovatek Parts like led plug, bay mount, square mount etc.?
The plugs and anything that screw into the res will work, they are both G1/4 thread. I have no idea if the mounts will work or not.Quote:
btw what size are those hex screws? I have a hard time finding a key for the plug and the screws. Also, people you open up the res to clean it as sometimes the machining isnt as clean as one hopes. U dont want any tiny strips of delrin clogging ur blocks.
The plugs are 6mm HEX and the little buttonheads are 5/64"Quote:
Originally Posted by situman
Nik YHPM...I left you some HEAT. Waiting for you to do the same. Thanks!
Looks awesome sdkevin, more pics people! :p: lol
Usama aka Ferrari Freak
