[hwbot] 6686 - Presler 930 @ 3839Mhz - HIS X1900XTX @ 738 / 864mhz [/hwbot]
Using Catalyst 6.4's
http://service.futuremark.com/compare?3dm06=313973
http://img125.imageshack.us/img125/6...3mhzx19.th.jpg
[hwbot] 4514 - MSI K8N Neo4 Plat - A64 3200+ Venice 2.7GHz 1.6v - 2x512MB Ballistix 271MHz 3-3-3-8 - X1800XT 720/820 Stock Cooling [/hwbot]
http://service.futuremark.com/compare?3dm06=316942
[hwbot] 5111 - Presler 930 @ 4015Mhz - XFX 7900GT @ stock 520 / 750mhz [/hwbot]
http://service.futuremark.com/orb/pr...projectType=14
[hwbot] ~JIN~tanjt - 8203.00 - AMD X2 4400+ @ 2638MHz | GeForce 7900GX2 @ 525/650MHz - [/hwbot]
first time hooho
http://i5.photobucket.com/albums/y192/tanjt/8203_06.jpg
[hwbot] CometMan - 7507 - FX60 @ 3412mhz X1900XTx @ 801/1682 [/hwbot]
http://service.futuremark.com/compare?3dm06=324751
[hwbot] 6789 - Presler 930 auto vcore @4098Mhz - HIS X1900XTX @ 738/864 air [/hwbot]
http://service.futuremark.com/compare?3dm06=329381
Catalyst 6.4 drivers
Outdated!
[hwbot] itznfb - 6063 3DMarks - AMD Opteron 165 @ 2755MHz - single XFX 7900GT @ 675/830[/hwbot]
http://service.futuremark.com/compare?3dm06=336729
That avatar is rather disturbing.
[hwbot] 6917 - Presler 930 @ 4286Mhz - HIS X1900XTX @ 733 / 864 all air cooled [/hwbot]
Catalyst 6.5 drivers
http://service.futuremark.com/compare?3dm06=339699
*delete*
Hey, it also says on the first page ranking list that I have a Conroe & CF X1900XTX ! I'm also listed as no.2... wtf ! :nono:Quote:
Originally Posted by blossa
But you got a great score! ;)Quote:
Originally Posted by IluvIntel
@ IluvIntel: It doesn't anymore, so can't say what that was about.
You did manage to steal blossa's result though. :D
You should not quote the score lines. This false submission is blocked now and disappears when the ranking updates.
@ blossa: this keyword matching problem looks interesting, maybe report it at hwbot forums. ;)
I unchecked the SLI/CF so you will get a medal position in the hall of fame. Congrats!
-mtzki
Thanks for the medal! ;-) My score is correct but i think you/someone did something wrong with IluvIntel points. We now have the same score...
I will try the hwbot-forums (when I find it) about the keywords, I would also like to see nr #1 on the singel card list. I guess that is a hwbot-forum-question also or have I missed something?
[hwbot] DjLeco - 8085 - single MSI X1900XTX @ 772/1782, P4 930@ 4681 [/hwbot]
Single card, all on watercooling!
Your comments, please!:stick:
The double score was caused by IluvIntel's quotes. My earlier comment was about that. It's fixed now.Quote:
Please visit http://www.hwbot.org/. I guess this website should be more pronounced in the first message. Here's the 3DMark06 hall of fame.
[hwbot] 7113 - Core Duo @ 3.08Ghz - Club X1900XTX @ 750/850mhz [/hwbot]
http://service.futuremark.com/compare?3dm06=343217
[hwbot] DjLeco - 8437 - single MSI X1900XTX @ 776/1790, P4 930@ 4731 [/hwbot]
Link: http://service.futuremark.com/compare?3dm06=344309
for PRO users,or printscreens for all users.
RESPECT from Romania!
With all apologies,I have a question:
What I obtained,there, IS or ISN'T an WR on 3D2006 On PentiumD with X1900XTX single card category?
Thank you for your answer(s)!
You have disabled post-processing, so i think the entry must be blocked from hwbot. Use the default settings.
Nice clocks, but not quite what the nordichardware guys have here.
Ok man, next test, I will do with default settings on 3D mark, but searching a little ,on ORB, there are a lot of users in top with post processing disabled like mine:slapass: ...
What bout' this?
Those scores do not get to halls of fame. One could just as well decrease the resolution...
[hwbot] N15M0 - 5710 - single Powercolor X1900XT @ stock, Opteron 165@ 2610 [/hwbot]
http://img150.imageshack.us/img150/5...stock065or.jpg
[hwbot] 10087 - Core Duo @ 3.1Ghz - 7950 GX2 @ 615/1500 [/hwbot]
http://service.futuremark.com/compare?3dm06=346285
