Don't know Puni.. mine also yesterday had one day to expiration date... :(
hello, yesterday mine showed only 1 day and today it says that i have 3 days...Quote:
Originally Posted by Punisher!
so try to reopen it or redownload it and try again to open it...meaby it will works... :)
Could someone dump the OCZ VX PC3200 for me or would it be ok to use the VX PC4000 dump on them? (dont know if maybe there's a difference in secondary timings.....)
UP please :worship: :worship:Quote:
Originally Posted by Langley
When im home, i will get the geil one es dumps from a friend
Thank you very much ;) :banana:Quote:
Originally Posted by Waus-mod
Does it work?Quote:
Originally Posted by [ITA]SEREUPIN80
I have a pair of Geil One-S TCCD 512MB,and this is the dump, may be someone need it
http://www.xtremesystems.org/forums/...1&d=1140420522
Hi, what's up??? Did you found the Dump of Geil One S or ES ???Quote:
Thanks ;)
@Waus-mod
I have 2x512 OCZ PC4000 VX mems, and I crashd one of them it with 3,7v vdimm in a dfi nf4 board, but it isn't any phisical demages on the stick, but it doesn't gave me any signal.. :nono: what do you think, can I fix it with this spd change??
and where can I find for my mem spd bios?
thx :rolleyes:
@achill3us : if one of them still good, you can make dump from it, then rewrite it to the bad one ...
@zungkono
I'm trying, I'm trying.. and I havent said that my bad stick works fine if i put it before useing in the icebox for 15 minutes :stick: but I shotdown my machine, restart, and no signal again..
Somebody can give me a 100% good OCZ5001024ELDCGEVX-K dump? pls :D
A picture of those pins that should be left open would be a good idea? :)Quote:
Originally Posted by Micutzu
(Not everyone sees those tiny numbers on PCB)
http://img106.imageshack.us/img106/3...19af5rd.th.jpg
The red pins need to be left uncovered. Sorry i couldn't find a Mushkin pic :)
Heh, i don't mind about it :)
@Waus-mod, can you put that image to first post as well?
My friend has give me the dump of 1gig OCZ 4000 VX Gold, but my problem stays, I think I must move my ram back to OCZ :(
But If somebody need this dump, here is the good one.. ;)
Could you clarify exactly when you inserted the stick?Quote:
Originally Posted by snatchmonkey
Anyone else attempted this?
yes, i think that it worked well last time that i used it:)Quote:
Originally Posted by Achill3uS
great ! thank you man... do you have some idea about the why your ram is dead ? i also lost one module 3 weeks ago...:confused:
my crapy mushkin pc4000 stick still doesnt work even after flashing! it works only if installed while red dram led is lighting! i guess it means that ps is turned on and there is voltage in ram slots! but after shutdown and and turning on, board just beeps error sygnal! so i have to get red led lighting again and then install the stick again!
I'm going to use an old-school BH-5 spd at a BH-UTT stick to see if it fixes the problems that the intel 865 and 875 chipsets can't do high speeds with this RAM.
I need a 256mb BH-5 single-sided spd proferably Kingston or another high overclocking BH-5 brand. I see a lot of spd's but no users have specified if they are single-sided or double-sided sticks.
Can someone please posts a 100% confirmed single-sided spd or can say which spd that has been posted already is single-sided?
Thanks ;)
Alex, it doesn't matter if the sticks are SS or DS, the SPD is the same; you can use any 256MB BH-5 SPD posted here, any of them will work just fine.
And by the way, SPD can make a difference in max clocks only with motherboards that don't have full options for setting the RAM timings or when you are using "Auto" settings. If you are manually setting all the timings, the SPD won't make any difference.
Edit: i've used Corsair 3200LL SPD on a 256MB single-sided BH-5 module i have made, and it works OK.
you wellcome :) I havent got a clue.. but it was interesting, I give them 3,7v on the window, it was -10C, the mem was icecold, and everything was fine, but after this shutdown, and restart doesn't work as befor.. :stick:Quote:
(a little off, but its amazing too the ups send the memory to ocz tech. in netherlands for ~70$ :slobber: )
I have a single sided 256mb bh-5 here, it was a-data in the old times :D i can dump for you today.. (on 3,8v can ~285mhz 2-2-2 :) )Quote:
Originally Posted by alexio
Thanks man, but not really needed. First I'm gonna extensively test the new BH-5 spd on the 865 chipset. This include maximum full PAT testing. I'll let you know how it went, or even start a thread if the outcome is thread-worthy.Quote:
