:lol: good one mateQuote:
Well, you could try disabling C'n'Q in the BIOS and try this little app called RightMark CPU Clock Utility instead:
http://www.zen15326.zen.co.uk/Forum_...reenshot_1.png
http://www.zen15326.zen.co.uk/Forum_...reenshot_2.png
http://www.zen15326.zen.co.uk/Forum_...reenshot_3.png
http://www.zen15326.zen.co.uk/Forum_...reenshot_4.png
The settings are applied when you boot Windows, and should therefore provide a much safer method than the motherboard's C'n'Q operation. Hopefully it will fill all your needs...
A little late now don't ya think............... I've tried Rightmark on several boxes with little success........
I wouldn't know...............Quote:
Originally Posted by pcdoc1
What went wrong exactly?Quote:
Moin, moin,
Not to nitnick, but we also need people who have working Expert or RDX boards to report in ;)Quote:
[EDIT: I mean in the poll thread, not here]
so if we own the org release of this mb how do we get a newer revision? i have the org release like may of you and mine wont let me change the voltages it will only work if i leave it on auto. with all the dead cpus from this mb im not about to go trying to figure out why its not allowing me to adjust the voltages. for now i just put my ultra-d back in until things get sorted out. will DFI rma this mb for me? kinda sucks to have 200 bucks tied up in somthing your afraid to use... i gues i can look at the bright side of things atleast its only 200 bucks and not a 1000 dollar cpu..
thx perc,
Ok. So far, so good. Building a new system using expert board with my old 3200 and OCZ rev 2 TCC5, running 10x250 at stock volts. Had no problems with initail start up. Haven't yet had a chance to see if I can get a higher overclock, still installing all my apps. This chip was 3d stable at 2.8, and prime stable at 2.65. Using shipping bios. Temps do seem way low, though. My case temp is 26C and SG is showing idle at 22C, lolQuote:
Originally Posted by Martin Cracauer
About revisions:
Over at dfi-street it was said that DFI has the PCBs made in huge chunks. They are then stored and as the market takes them chunks are taken out, the chips put on and a BIOS installed.
In that posting it was said that the revision number that is on the sticker on one PCI slot only indicates the BIOS version installed. That all Expert boads so far are the exact PCB, at that there's no way to tell newer chipsets from the revision number.
How the latter plays with the cuts we have seen on some but not all Experts I'd say is a good question/
No, I don't remember where exactly that posting was. But "expert" and 'revision" as search terms might do it quickly.
What board revisions are there so far?
I just received my Expert and i think...if i'm reading the right spot at least my revision is AAO? :S
Well once the board goes up in smoke and takes a 170 with it, it's a little late........ Read the rest of the thread.Quote:
Originally Posted by Undesirable
and not just any CPU....that was a 0530TPMW :(
I had read the rest of the thread, but wasn't sure exactly what you were referring to. Thanks for clarifying.Quote:
just to clarify S3 doesn't work right on the "non" expert boards either.....
I get the same behaviour on my SLI-DR
It was suggested by AG @ the street to not use S3 when O/C'd on the regular boards and the same should apply to the expert
why? id just like to know how many people with dead boards there are, we all know that most boards work totally fine, but nobody knows how many boards have died already. 12? 25? 40?Quote:
Hi all , I have been folowing this thread plus many others at other forums regarding the expert MoBo and posted this same question. It appears that no one has actually done an accurate count of cpu's actually killed as well as other components at any of the forums.Quote:
Who wants to start? What we need is some real:fact:
hi dinos22Quote:
Originally Posted by dinos22
what bios are you using, the one shipped with the board,, I presume you haven't flashed yet?
you crack me up!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!1:clap: :clap: :clap: :clap: :clap: :clap: :clap: :clap: :clap: :clap: :clap: :clap: :clap: :clap: :clap: :clap: :clap: :clap: :clap: :clap: :clap: :clap: :clap: :clap: :clap: :clap: :clap: :clap: :clap: :clap: :clap: :clap: :clap: :clap: :clap: :clap: :clap: :clap: :clap: :clap: :clap:
on original 11-02Quote:
Originally Posted by lmat
dinos22, are both of your eXpert ram slots working properly ? My yellow slots seem to not working right. I can't ran BH-5 on the yellow slot, it won't boot but run fine with orange slot.
My eXpert seems to "hate" BH-5, have to run@its spec rating to stable in windows or got BSOD :S
i always run RAM in slots closer to CPU....so 1 and 3Quote:
Originally Posted by nop
you know i tested some old school BH5 last week and I couldn't even get them to run SPD FFS......maybe you're onto something there....but seeing how many people run BH5 fine there's probably nothing in that.........anyways my G.Skill LEs are happily crunching away
Well, it's a poll and people use the number to figure how much of a chance there is that a random board blows something up.Quote:
Obviously to do that you need the base number of all boards, including the working ones.
k, lets make a new list with just the dead/faulty boards/cpus/memory then :PQuote:
the idea to want to know how big their chance is to get a faulty board is understandable, but doesnt make any sense.
its not that theres a fixed percentage of boards that goes belly up, at least thats not what it looks like if you ask me.
Instead of letting this thread slide off topic or get conjested with alot of "I haven't had a problem" post, how 'bout someone just starting a poll thread we can monitor.......:)Quote:
There already is one... :)Quote:
http://www.xtremesystems.org/forums/...ad.php?t=82319
I wonder if DFI engineers have been able to reproduce this issue yet on the Expert? At this point I guess we aren't really sure what excatly the issue even is. Can anyone at X possibly get some sort of interim statement from Oscar Wu? Even a "don't do this" or "set this to xxx" while they are investigating would go a long way to help.
